  2. Allegro X Scripting - TCL
  3. TCL to set active page in the treeview using SelectPMIt...
  • Subscribers 14
  • Views 915
TCL to set active page in the treeview using SelectPMItem
fSeyer
fSeyer 6 months ago
Could anyone suggest an alternative to SelectPMItem?
I’m using it to set the active page in a tree view, but it ignores page names that contain "0".
  • TechnoBobby
    0 TechnoBobby 6 months ago
    Hi fSeyer ,
    Could you clarify what you do after selecting the page in the Project Manager tree?
    Do you need the page selected only to make it active in the UI, or are you selecting it to obtain a DboPage and perform further operations on it?
  • fSeyer
    0 fSeyer 6 months ago in reply to TechnoBobby
    Hi TechnoBobby,
    Thanks for respond!
    i have a UI that listed all the pages, my intend is to to print pdf or generate Bom for either per page or all page.
    usually we set page name stars from 01_circuit name ~ 10_circuit name.
    i notice that only page name without "0" can used by SelectPMItem.
    here's my code
    set sel [.pageReport.lb curselection]
    if {$sel eq ""} return
    set idx [lindex $sel 0]
    set text [string trim [.pageReport.lb get $idx]]
    if {$text eq "ALL PAGES"} {
    set lDesign [GetActivePMDesign]
    set lDesignName [DboTclHelper_sMakeCString]
    set lsts [$lDesign GetName $lDesignName]
    $lsts -delete
    set fullPath [DboTclHelper_sGetConstCharPtr $lDesignName]
    set splitPath [file split $fullPath]
    set dsnName [file rootname [lindex $splitPath end]]
    SelectPMItem "./$dsnName.DSN"
    catch {SelectPMItem "$text"}
