  2. Allegro X Scripting - TCL
  3. How do I use the TCL command to save an image and a Visio...
  • State Verified Answer
  • Subscribers 14
  • Views 1124
How do I use the TCL command to save an image and a Visio drawing file from a DSN file as a new file?
FK202606088435
FK202606088435 3 months ago
My current version is 23.1. How do I use the TCL command to save an image and a Visio drawing file from a DSN file as a new file?
I've tried the Base64 decoding mentioned on pages 762 and 767 of the OrCAD_Capture_TclTk_Extensions.pdf file, but it's not working. The code snippet provided is:
Invalid command name "DboTclHelper_sGetBase64ImageData"
  • TechnoBobby
    TechnoBobby 3 months ago +1 verified
    Hi FK202606088435 , Please try the following TCL code on a selected image on schematic page: set bmpInst [GetSelectedObjects] set bmp [$bmpInst GetDboBitMap] set outStr [DboTclHelper_sMakeStdStr ""] set…
  • TechnoBobby
    +1 TechnoBobby 3 months ago
    Hi FK202606088435 ,
    set status [DboState]
    DboBitMap_sGetBase64ImageData $bmp $outStr $status
    set base64Data [DboTclHelper_sGetConstCharPtr $outStr]
    COrBase64Encoder_decodeToFile $base64Data "c:/temp/image.png"
    Hope this helps!
  • FK202606088435
    0 FK202606088435 3 months ago in reply to TechnoBobby
    Nice solution! Thank you very much.
    Regarding retrieving the text content and formatting from a circuit page using TCL commands,
    I need the text content, text size, font, and font style.
    I'd like to ask if there are TCL commands that can extract the same information as in File→Export→Design XML in the following UI interface?
    <GraphicCommentTextInst>
    <Defn color="48" dbId="1715717" locX="21" locY="19" name="001 COVER PAGE" rotation="0" textJustification="0" x1="21" x2="261" y1="19" y2="47"/>
    <TextFont>
    <Defn charset="0" escapement="0" height="-27" italic="0" name="Arial" orientation="0" weight="700" width="0"/>
    </TextFont>
    </GraphicCommentTextInst>
    Below is an example of an error I encountered when trying to retrieve font format, text size, and text font:
    # Retrieving LOGFONT object index (but pure TCL cannot parse its internal fields)
    # set lFont [DboGraphicCommentTextInst_sGetFont $lTextInst $lStatus]
  • TechnoBobby
    0 TechnoBobby 3 months ago in reply to FK202606088435
    Hi FK202606088435 ,
    To retrieve the text content, you can try:
    set lObjs [GetSelectedObjects]
    set lComment [$lObj GetDboCommentText]
    set txt [DboTclHelper_sMakeCString]
    $lComment GetText $txt
    puts "Text: [DboTclHelper_sGetConstCharPtr $txt]"
    You can also iterate through the effective properties of the selected text object which will return text, bounding box, font name, etc:
    proc EffectivePropsAll {lObject} {
    set lStatus [DboState]
    set lPropsIter [$lObject NewEffectivePropsIter $lStatus]
    set lPrpName [DboTclHelper_sMakeCString]
    set lPrpValue [DboTclHelper_sMakeCString]
    set lPrpType [DboTclHelper_sMakeDboValueType]
    set lEditable [DboTclHelper_sMakeInt]
    set lStatus [$lPropsIter NextEffectiveProp $lPrpName $lPrpValue $lPrpType $lEditable]
    while {[$lStatus OK] == 1} {
    puts "[DboTclHelper_sGetConstCharPtr $lPrpName] = [DboTclHelper_sGetConstCharPtr $lPrpValue]"
    delete_DboEffectivePropsIter $lPropsIter
    EffectivePropsAll [GetSelectedObjects]
    Hope this helps!
