  2. Allegro X Scripting - TCL
  3. How to use TCL commands to retrieve text content and formatting...
  • Subscribers 14
  • Views 723
How to use TCL commands to retrieve text content and formatting from a circuit diagram page
FK202606088435
FK202606088435 3 months ago
Regarding retrieving the text content and formatting from a circuit page using TCL commands,
I need the text content, text size, font, and font style.
I'd like to ask if there are TCL commands that can extract the same information as in File→Export→Design XML in the following UI interface?
<GraphicCommentTextInst>
<Defn color="48" dbId="1715717" locX="21" locY="19" name="001 COVER PAGE" rotation="0" textJustification="0" x1="21" x2="261" y1="19" y2="47"/>
<TextFont>
<Defn charset="0" escapement="0" height="-27" italic="0" name="Arial" orientation="0" weight="700" width="0"/>
</TextFont>
</GraphicCommentTextInst>
Below is an example of an error I encountered when trying to retrieve font format, text size, and text font:
# Retrieving LOGFONT object index (but pure TCL cannot parse its internal fields)
set lFont [DboGraphicCommentTextInst_sGetFont $lTextInst $lStatus]
Best Regards,
  • CadAP
    0 CadAP 3 months ago
    Try below api for text fontsize and fontname.
    DboTclHelper_sMakeLOGFONT(lfFaceName, lfHeight, lfWidth, lfEscapement, lfOrientation,
    lfWeight, lfItalic, lfUnderline, lfStrikeOut,
    lfCharSet, lfOutPrecision, lfClipPrecision,
    lfQuality, lfPitchAndFamily) : returns LOGFONT
    For example, setting text arial and text size 10
        set fntpbj [ DboTclHelper_sMakeLOGFONT "Arial" 16 0 0 0 400 0 0 0 0 7 0 1 16]
  • FK202606088435
    0 FK202606088435 3 months ago in reply to CadAP
    Sorry, maybe my question wasn't clear.
    I wanted to capture all the formatting specifications of the text already on the page.
    Although the built-in UI's Export --> XML shows detailed text font specifications, that file is too huge, so I only want to capture the text content.
    This is my failed command:
    set lFontFaceName [$lFont cget -lfFaceName]
    set lFontHeight [$lFont cget -lfHeight]
    set lFontSize [expr {abs($lFontHeight)}]
    set lFontWeight [$lFont cget -lfWeight]
    set lFontItalic [$lFont cget -lfItalic]
    set lFontUnderline [$lFont cget -lfUnderline]
    puts $outFile " <TextFont>"
    puts $outFile " <Defn fontName=\"$lFontFaceName\" fontSize=\"$lFontSize\" fontWeight=\"$lFontWeight\" italic=\"$lFontItalic\" underline=\"$lFontUnderline\" />"
    puts $outFile " </TextFont>"
