  2. Allegro X Scripting - TCL
  3. TCL Script to check the property of component in system...
  • State Verified Answer
  • Subscribers 14
  • Views 331
TCL Script to check the property of component in system capture.
MZ20250602835
MZ20250602835 1 month ago
Dear all,
i try to make a tcl script to looks up components on each page in system capture. If a component has the property VAR_1, it enters the VAR_1 variant view(i created a variant with name VAR_1), marks that component as Do Not Install (DNI), and cleanly exits the variant view using variantOFF.
the following is my codes: unfortunately it does`t work may i ask how could i correct these codes to make it work? many thanks Moyan.
# setSelfToDNI
# This procedure looks up components on each page. If a component has the
# property VAR_1, it enters the VAR_1 variant view context, marks that component
# as Do Not Install (DNI), and cleanly exits the variant context using variantOFF.
proc setSelfToDNI {} {
# 1. Initialize environment settings and Batch Mode matching your master structure
sch::enterBatchMode
# Optional structure hook: Configure project settings to keep variant structures active
configureProjectExp -variant true
configureProjectExp -blocks true
configureProjectExp -library false
# 2. Get all page information using the schPageUtils structural format
set pageInfoAll [schPageUtils::getDesignPagesAllInfo]
set pageSize [schPageUtils::getPagesInfoSize $pageInfoAll]
puts "--- STARTING STRUCTURAL DNI COMPONENT SCAN ---"
puts "Total project pages to process: $pageSize"
# 3. Iterate over each sheet using the exact loop constraint from your master code
for {set i 1} {$i <= $pageSize} {incr i} {
set viewId [schPageUtils::getPageId $pageInfoAll $i]
set pageName [schPageUtils::getPageName $pageInfoAll $i]
puts "Opening page context: $pageName"
openItem $viewId SCH PAGE
set pageId [sch::dbGetActivePage]
set itemId [sch::dbGetPageItems $pageId]
# 4. Traverse canvas objects on the active page
foreach item $itemId {
# Extract the user-facing text label identifier (RefDes text block)
set compRefDes ""
catch {
set compRefDes [sch::dbGetItemText $item]
# If the item doesn't contain reference designator text context, pass it
if {$compRefDes eq ""} {
continue
# Map the graphical item pointer directly to its root logical block definition
set compInst ""
catch {
set compInst [sch::dbGetCompInst $item]
if {$compInst eq ""} {
continue
# 5. Look up the presence of the target VAR_1 property on the logical instance block
set hasVar1 0
set var1Value ""
if {![catch {
set var1Value [sch::dbGetPropValue $compInst VAR_1]
if {$var1Value ne ""} {
set hasVar1 1
# 6. If match is verified, execute your variant isolation and toggle pipeline
if {$hasVar1} {
puts " -> Found Component $compRefDes on $pageName with VAR_1 property."
# Step A: Jump into the targeted "VAR_1" variant viewing perspective
puts " Entering variant view context via 'viewVariant -variant VAR_1'..."
if {[catch {viewVariant -variant VAR_1} err]} {
puts " [Warning] Failed to switch to variant view mode 'VAR_1': $err"
continue
# Step B: Re-instantiate the canvas window pointer inside the variant configuration plane
# Step C: Isolate and highlight the target element matching your selection framework
unselectObject -all
sch::dbSelectObjectById $item $sch::DBTrue
# Step D: Apply the structural property change marking the part to Do Not Install
if {[catch {setDNI -variant VAR_1 -comp $compRefDes -state true} err]} {
puts " [Warning] Could not flag component $compRefDes as DNI: $err"
} else {
puts " [Success] Component $compRefDes successfully marked DNI inside VAR_1."
# Step E: Safely step back into the base schematic workspace via variantOFF as requested
puts " Exiting variant tracking context via 'variantOFF'..."
if {[catch {variantOFF} err]} {
puts " [Warning] Failed to execute structural command variantOFF: $err"
# Step F: Reopen the base schematic context so downstream loops keep valid data pointers
# 7. Close and cycle the page context matching your structural pattern
closeItem $viewId
# 8. Commit changes globally and finalize execution
saveAll
sch::leaveBatchMode
puts "--- COMPLETED DNI TRACKING PIPELINE SUCCESSFUL ---"
  • MZ20250602835
    MZ20250602835 1 month ago +1 verified
    Dear all, i found the solution How to filter components based on a specific property, add those components to a variant, and mark them as DNI
  • MZ20250602835
    +1 MZ20250602835 1 month ago
    Dear all,
