  2. Allegro X Scripting - TCL
  3. how to create a design file in capture using tcl
  • State Verified Answer
  • Subscribers 14
  • Views 911
digital1
digital1 1 month ago
Im trying to create a design in capture programatticaly using tcl here is my code so far
# Get the existing DboSession
set lSession $::DboSession_s_pDboSession
DboSession -this $lSession
# Create a DboState
set lStatus [DboState]
# Build a test directory underneath the Capture workspace
set workspace [::orcad::startpage::getCapWorkspacePath]
set projectsDir [file join $workspace "projects"]
set testDir [file join $projectsDir "DboTest"]
file mkdir $testDir
# Define the design name/path
set designPath [file join $testDir "DboTest.dsn"]
set rootName "DboTest"
# Create CString objects for the CreateDesign API
set designNameCString [DboTclHelper_sMakeCString]
DboTclHelper_sSetCString $designNameCString $designPath
set rootNameCString [DboTclHelper_sMakeCString]
DboTclHelper_sSetCString $rootNameCString $rootName
# Create the DboDesign
set lDesign [$lSession CreateDesign  $lStatus  $designNameCString   $rootNameCString]
# Get the root DboSchematic
set lRootSchematic [DboDesign_GetRootSchematic  $lDesign  $lStatus]
# Create the first schematic page
set pageNameCString [DboTclHelper_sMakeCString]
DboTclHelper_sSetCString $pageNameCString "Page 1"
set lPage [$lRootSchematic NewPage  $lStatus  $pageNameCString]
# Save the Dbo design
DboSession_SaveDesign $lSession $lDesign
although this saves the design file it does not save it as an opj file as well also there is no file view or hierarchical view in the capture window.
i have to exit out of capture and load the design file this creates the opj file and also creates the view window with the file and hierarchical view
Is there anyone out there that may know what i am doing wrong
Im doing the code in bits and pieces the end result is a kicad file importer for not only capture but later for pcb
Im doing this because kicad imports Altium Binary and CadStar binary format files and also has a pretty good gerber to pcb reverse engineering tool so i can save legacy files that we have lost the design tools for
  • TechnoBobby
    TechnoBobby 1 month ago +1 verified
    Hi digital1 , Since the design is being created through the Dbo API, and it is not being opened as a Capture project, so the OPJ and Project Manager views are not initialized until the design is reopened…
  • PatEscher
    PatEscher 1 month ago in reply to digital1 +1 verified
    The easiest way is to create the opj file manually through tcl. proc InitializeOpj {libraryName} { # initialize opj if not exists yet set base [regsub "(.*)(\.olb)" $libraryName "\\1"] set opjPath "$base…
  • TechnoBobby
    +1 TechnoBobby 1 month ago
    Hi digital1 ,
    Since the design is being created through the Dbo API, and it is not being opened as a Capture project, so the OPJ and Project Manager views are not initialized until the design is reopened.
    You can either use the GUI commands to create the project, or continue with the Dbo approach and reopen the design for doing further processing.
    To discover the GUI commands, enable journaling in the Capture Command Window:
    SetOptionBool Journaling TRUE
    Then manually create a project and review the recorded commands.
    If you would like to continue with your current approach, then after saving the design, remove the design from the session using below commands:
    $lSession RemoveDesign $lDesign
    # Delete the session
    DboTclHelper_sDeleteSession $lSession
    # Open the DSN in Capture
    Open {C:/path/to/DboTest.dsn}
    And then continue all further processing on the design opened.
    Hope this helps!
  • digital1
    0 digital1 1 month ago in reply to TechnoBobby
    Hi TechnoBobby
    Thank you that worked however this bit i didnt like
    although it worked it gave me a dialog box to click ok on is there any way it can be done without this dialog box.
    Other than that im happy with the result
  • PatEscher
    +1 PatEscher 1 month ago in reply to digital1
        set opjPath "$base.opj"
        set fexist [file exist $opjPath]
        if {!$fexist} {
            set filename [file tail $libraryName]
            set opjContent [open "$opjPath" "w"]
            puts $opjContent {(ExpressProject ""}
            puts $opjContent {  (Folder "Design Resources"}
            puts $opjContent {    (Folder "Library")}
            puts $opjContent "    (File \".\\$filename\""
            puts $opjContent {        (Type "Schematic Library"))}
            puts $opjContent {    (DOCKED "TRUE")}
            puts $opjContent {    )}
            puts $opjContent {)}
            close $opjContent
  • digital1
    0 digital1 1 month ago in reply to PatEscher
    Thank you PatEscher  This allowed me to open and see the project structure without any further dialog boxes Although I liked TechnoBobby  version but it gave me a dialog box that needed some user activity. Both versions are valid though.
    I started this project about a year ago because i couldnt get it past the project view stage so thank you guys I can revisit this project and hopefully have a kicad file imporrter for Orcad
