  3. How to interconnect tool between system capture with PCB...
  • Subscribers 32
  • Views 13867
How to interconnect tool between system capture with PCB editor ??
kabalee
kabalee over 4 years ago
HI everyone,
i am new for System capture. can any one tell me how to inter connect the tool between system capture and PCB Editor ? like below.
In orcad capture option are marked in red color . like that how to enable this option in SYSTEM CAPTURE 17.4
if i select any symbol in system capture .it should  be select related components in PCB editor. is it not enabled .  Kindly help any one pls
  • atishcdns
    atishcdns over 4 years ago +1
    In System Capture on the bottom left you will see a toggle button called Auto XProbe. By default, it is turned off. If you would like to enable cross probing you need to turn it on.
  • atishcdns
    0 atishcdns over 4 years ago in reply to kabalee
    Crtl + left mouse button to select multiple components.
