  3. How to interconnect tool between system capture with PCB...
  • Subscribers 32
  • Views 13866
How to interconnect tool between system capture with PCB editor ??
kabalee
kabalee over 4 years ago
HI everyone,
i am new for System capture. can any one tell me how to inter connect the tool between system capture and PCB Editor ? like below.
In orcad capture option are marked in red color . like that how to enable this option in SYSTEM CAPTURE 17.4
if i select any symbol in system capture .it should  be select related components in PCB editor. is it not enabled .  Kindly help any one pls
  • atishcdns
    atishcdns over 4 years ago +1
    In System Capture on the bottom left you will see a toggle button called Auto XProbe. By default, it is turned off. If you would like to enable cross probing you need to turn it on.
  • atishcdns
    0 atishcdns over 4 years ago
  • kabalee
    0 kabalee over 4 years ago in reply to atishcdns
    Hi Thanks for your reply
  • kabalee
    0 kabalee over 4 years ago in reply to kabalee
    if i need to select symbol in system capture .. what is the option
  • atishcdns
    0 atishcdns over 4 years ago in reply to kabalee
    You should be able to select the component by clicking the left mouse.
  • kabalee
    Hi Thanks for your reply.
    what is the option to select multiple components at the time ?? (like capture CIS 17.2 )
     as well if need to select multiple of nets what is the option. Kindly response pls
