  3. SysCap - Tip of the Week: Changing the grid units from inches...
  • Subscribers 50
  • Views 8147
SysCap - Tip of the Week: Changing the grid units from inches to millimeters
DesignTech
DesignTech over 4 years ago
By default, the grid unit is in inch because Cadence-provided Standard libraries use inches for all components.
If your libraries use millimeters, you can change the unit from inches to millimeters by modifying the site-level cpm file.
Change the following in the START_CANVAS section of the site.cpm file:
GRID_UNIT_MEASURE 'INCHES'
GRID_PIN_PITCH '0.1'
To:
GRID_UNIT_MEASURE 'MILLIMETER'
GRID_PIN_PITCH '1.00'
The changed grid unit will come into effect when Allegro System Capture is restarted.
Team DesignTech
Cadence Design Systems
  • chiefsweater
    chiefsweater over 4 years ago
    You may convert the unit from inches to millimeters by altering the cpm file that is located on the site level. This is only necessary if your libraries already use millimeters.
    dordle
  • bevis0405
    bevis0405 over 4 years ago
    After changing the grid units from inches to millimeters, select two grid lines and then enter values into those two grid lines. After entering those values, you should be able to see that they are both displaying the same value even though you started with two different sets of grid units.
    drift hunters
  • JJ202410167612
    JJ202410167612 over 2 years ago
    Thanks to Team DesignTech for sharing this useful information! Converting the grid unit from inches to millimeters will help to better match libraries that use millimeters. Looking forward to more great tips from you!
    rice purity test meaning
  • JJ202410167612
  • CP202604075044
    CP202604075044 7 months ago
    This is a helpful tip for those using metric libraries! I've definitely run into situations where misaligned grids cause headaches. Remembering to adjust the GRID_PIN_PITCH is crucial – especially when dealing with complex layouts. It's easy to overlook these seemingly small details, but they have a huge impact on ensuring a consistent design. It's like a Slope in the foundation, get it wrong and everything above suffers! Thanks for sharing this reminder.
