  3. SysCap - Tip of the week: Exporting notes from a design...
  • Subscribers 30
  • Views 1247
SysCap - Tip of the week: Exporting notes from a design to a spreadsheet
DesignTech
DesignTech over 4 years ago
In System Capture, you can find all notes in the design and export them to a csv file using Tcl commands.
Use the following command to find notes in the design:
find -scope "Entire Design" -types "note" {}
Export results to a csv file using the following command:
cps::dumpSearchResults <path to folder> <string suffix>
For example,
cps::dumpSearchResults ../search_data "design_notes"
Ensure that the specified folder exists.
This will export design notes to a file named ‘search_result_Notes_Design_Notes.csv’ in the ‘search_data’ folder.
Team DesignTech
Cadence Design Systems
