  3. Why to use Allegro System Capture – Smart PDF
  • Subscribers 31
  • Views 10539
DesignTech
DesignTech over 4 years ago
Allegro System Capture supports exporting the design data into Smart PDF. Using Smart PDF, you can quickly traverse through the design and view component attributes without accessing System Capture. This feature is especially useful when you need to view or share complex schematic designs.
To generate Smart PDF, select File > Print and choose the Smart PDF option from the dropdown.
Select the desired options to generate a Smart PDF. You can also add watermark and encrypt your PDF.
Team DesignTech
Cadence Design Systems
  • Schulz Jordan
    Schulz Jordan over 4 years ago
    Does this require a Design publisher license or works with default license or system capture ?
  • atishcdns
    atishcdns over 4 years ago in reply to Schulz Jordan
    no additional license is required for the feature
