  3. SysCap – Tip of the Week: Using Filters in Unified Sear...
  • Subscribers 27
  • Views 5247
SysCap – Tip of the Week: Using Filters in Unified Search
DesignTech
DesignTech over 2 years ago
System Capture Unified Search provides advanced search options by using Filters to help you quickly find the part you are looking for.
Click on Filters in Unified Search and you will see the various filter options like VALUE, TOLERARNCE, and so on.
Unified Search Filters
Use the required filter to narrow down the search results.
Applying Filters in Unified Search
Team DesignTech
Cadence Design Systems
  • exp626
    exp626 over 1 year ago
    Is the Filter option in Unified Search only available on certain versions of Allegro? I am running Allegro X System Capture 23.1.S002 and I do not see it.
    Thank you!
  • srish09
    srish09 over 1 year ago in reply to exp626
    Do you see filters when you switch to a different tab in Unified Search like Library or My Parts?
