  3. SysCap – Tip of the Week: Assigning a RefDes range for hierarchical...
  • Subscribers 29
  • Views 4843
SysCap – Tip of the Week: Assigning a RefDes range for hierarchical blocks
DesignTech
DesignTech over 3 years ago
When working with hierarchical designs, you can assign a reference designator range for all components in the underlying block schematic.
Place a block on the schematic sheet, select Use Range in the Packaging Options for Block dialog box, and specify the reference designator range.
Packaging Options Use Range
This will control the assignment of reference designators for the block as per the defined range.
Team DesignTech
Cadence Design Systems
