  3. How does Schematic Audit check for missing pull-up? - [EAUDIT...
  • Subscribers 30
  • Views 1688
How does Schematic Audit check for missing pull-up? - [EAUDIT-43/44] Pin SCL/SDA missing pull-up
User999
User999 over 2 years ago
https://docs.google.com/presentation/d/19MlV-JEe9L6H4nGFRdXZKG8dLEcH1ag3/edit?usp=sharing&ouid=117334059194192322354&rtpof=true&sd=true
Audit Violations
How does System Capture 17.4 schematic audit check for the missing pull-up?
Sometimes it flagged when pull-up is not right after SCL/SDA pins (Slide 4), sometimes it flagged even when pull-up is right after SCL/SDA pins (Slide 6).
How should I set the rules differently to check this error more efficiently?
  • rg13
    0 rg13 over 2 years ago
    Pull up and pull down resistors related error depends on where we have connected them. Also, their maximum and minimum values which can be defined under 'Design Integrity > Configure > Schematic Audit settings' and then 'Parameters'.
