  3. Syscap power object name don't change
  • Subscribers 30
  • Views 2091
xmlee
xmlee over 2 years ago
I'm using syscap 221.s009
while drawing sch, i need to place power objects., for example, VDD.
after placing it onto the sch, it asks me to assign the voltage:
I thought the name of the object should be changed to VDD3V3, but it doesn't:
all power objects have the same problem.  How can i fix it?
  • rg13
    0 rg13 over 2 years ago
    VDD is just a note/text on symbol graphics to recognize the power symbol named VDD. While placing the power symbol on schematic, it asks you to name the power/ground net and its voltage value. Whatever name you give here, will be the name of connecting power net.
    Hope it clarifies!
    NOTE: To change the symbol graphics, you can open the Part developer (PDV) and can change the text over there.
