  3. SysCap-Tip of the Week: Topology flow with Allegro System...
  • Subscribers 38
  • Views 4164
SysCap-Tip of the Week: Topology flow with Allegro System Capture
DesignTech
DesignTech over 2 years ago
With SPB 23.1, TopXp is integrated with Allegro System Capture. This lets you explore the topology in TopXp from SysCap. Now, the constraints flow from the schematic to the board and can be edited and updated across tools.
It supports all Constraint-Manger-based ECSet creation/modification flows as well as simulation flows. Now, TopXp can be launched directly from the System Capture canvas.
TopXp offers two different views:
  1. ECSet View: In this view, you can see the end-to-end topology of a net/XNet/differential pair. You can also create new ECSets and modify the existing ECSets. All changes will be auto updated in Constraint Manger and docked Constraint Manger.
  2. Simulation View: In this view, you can simulate the extracted object (single net/XNet and differential pairs). This view will change depending on where the topology is extracted from.
To know more about this flow, refer to the extensive Rapid Adoption Kit available here.
  • FB202508189813
    0 FB202508189813 over 1 year ago
    • The integration ensures that constraints flow smoothly from the schematic in System Capture to the board design in TopXp. This means that any changes made to constraints can be easily edited and updated across both tools, enhancing consistency and reducing errors.
