  3. How to convert my system capture project to OrCAD Capture...
  • Subscribers 32
  • Views 4008
How to convert my system capture project to OrCAD Capture / Allegro Design entry CIS
RohitRohan
RohitRohan over 2 years ago
Hai Community,
I have a project which is designed in the Allegro System capture but now want to continue that project into the OrCAD Capture / Allegro Design Entry CIS.
How can I Convert my system capture project to the OrCAD Capture / Allegro Design Entry CIS.
Can anyone share me the procedure / steps to perform for the conversion.
Rohit Rohan
  • rg13
    0 rg13 over 2 years ago
    There is no way for this.
    Any reasons to translate Syscap project in Orcad? If you or your end users are facing any issues while designing/working on schematic in System Capture, I would suggest you to contact Cadence customer support team to get it addressed.
    If debugging issues in System Capture does not need any data sharing, you can describe them here as well.
  • Zhifeng Jin
    0 Zhifeng Jin 4 months ago
    In the latest SysCap 25.1 S030 release, you can directly select Save As OrCAD Capture Design (*.dsn) from the File menu.
