  3. Symbol part number update shortcut
  • State Verified Answer
  • Subscribers 30
  • Views 4118
VS20241218278
VS20241218278 over 1 year ago
I'm using capture cis 17.2 version for schematic, i placed all components, but I need an option to quickly update all passive symbols with their part numbers?
  • rg13
    rg13 over 1 year ago +1 verified
    You want to see part number property in property editor for all placed passive parts, right? If you have placed part from CIS database (CIS Explorer), Part Number is mandatory property if is set as Transfer…
  • VS20241218278
    VS20241218278 over 1 year ago in reply to rg13 +1 verified
    HI rg13 , if i changed part numbers in schematic, that part numbers need sync with Database, i expect if i change the part number for the symbol the whole parameter will be change in each symbol, its possible…
  • rg13
    +1 rg13 over 1 year ago
    If you have placed part from CIS database (CIS Explorer), Part Number is mandatory property if is set as Transfer to design then it should be visible in property editor.
    OR
    If there have been changes in database and you want to see those changes on existing parts on schematic, then open Part manager and select all the required parts and apply 'Update Selected Part status'
    Changes made in DB, will be reflected on schematic parts.
    Hope it helps!
    Let me know if you have any further question/concern on this.
  • VS20241218278
    +1 VS20241218278 over 1 year ago in reply to rg13
    HI rg13 ,
    if i changed part numbers in schematic, that part numbers need  sync with Database, i expect if i change the part number for the symbol the whole parameter will be change in each symbol, its possible or not ?, i did with Altium tool.
  • VS20241218278
    0 VS20241218278 over 1 year ago in reply to VS20241218278
    thank you for the information
