  3. Looking for basic example of TCL commands in System Capture...
  • State Verified Answer
  • Subscribers 30
  • Views 7996
Looking for basic example of TCL commands in System Capture such as adding a component, adding a wire to a pin, adding a netname to the wire, etc
Sermet
Sermet over 1 year ago
I know that System Capture supports TCL, and I found the documents for the API.
However, I am having a hard time finding an example of basic commands such as adding a component and connecting to a pin, attaching a netname to it, etc.
I can go run a command manually, check the corresponding TCL command in the Command window, and cross refence it in the TCL API documentation. That is definitely one way to do it.
But, I was expecting at least one example covering setting up a new page, adding some components, making connections, changing properties, etc.
  • CadAP
    CadAP over 1 year ago +1 verified
    Sermet Below script will add a page below to current open page and add a component (library =rf_comp_lib, sym_1 {CAPP2} ) and create a wire with net name test and add property TEST=123TE. Also…
  • CadAP
    +1 CadAP over 1 year ago
     Sermet
    Also add page before and after current open page is also added in the below script but those commands are commented.
    #add a page, component, props and create connection to it.
    #add a new page
    sch::addPageFromPageToolBar
    # add a page after current page
    # insertPageAfterCurrentPage $pageSpath SCH PAGE
    # Add a page before current page
    # insertPageBeforeCurrentPage $pageSpath SCH PAGE
    #Get Active page spath
    set pageSpath [sch::dbGetActivePageSpath]
    #Add a component on current page
    addComponent {rf_comp_lib} {capp2} sym_1 {CAPP2} -n 1 -key [list {CDS_LIBRARY_ID=rf_comp_lib:CAPP2=0} {CDS_LIBRARY_PHYSICAL_ID=CAPP2=0} {PART_NAME=CAPP2=0} {PART_NAME=CAPP2=0} ] -pg $pageSpath -r 0 -m 0 -pos [list 9200 7100]
    #Adding wire to pins.
    set lSelobj [getSel]
    set lSelPos [sch::dbConvertToUserUnits [sch::dbGetPos $lSelobj]]
    set lChildren [sch::dbGetChildren $lSelobj]
    addProp -name {TEST} -value {123TE} -type 0 -display valOnly
    foreach child $lChildren {
    set lWireEndPoint {}
    set lChildType [sch::dbGetType $child]
    if {$lChildType == $sch::DBTInstTerm} {
    set lPinHotSpot [sch::dbGetHotSpot $child]
    set lUserHotSpot [sch::dbConvertToUserUnits $lPinHotSpot]
    set lWireYEndPoint [lindex $lUserHotSpot 1]
    if {[lindex $lSelPos 0] > [lindex $lUserHotSpot 0]} {
    set lWireXEndPoint [expr "[lindex $lUserHotSpot 0] - 250"]
    lappend lWireEndPoint $lWireXEndPoint $lWireYEndPoint
    # drawwire {test1} [list $lPinHotSpot ] -1 -1
    } else {set lWireXEndPoint [expr "[lindex $lUserHotSpot 0] + 250"] ; lappend lWireEndPoint $lWireXEndPoint $lWireYEndPoint}
    # puts "$lWireXEndPoint $lWireYEndPoint"
    puts "[lindex $lUserHotSpot 0],[lindex $lUserHotSpot 1 ] [lindex $lWireEndPoint 0],[lindex $lWireEndPoint 1]"
    drawWire {test1} [list [lindex $lUserHotSpot 0],[lindex $lUserHotSpot 1 ] [lindex $lWireEndPoint 0],[lindex $lWireEndPoint 1]] -1 -1
    Hope it helps.
  • Sermet
    0 Sermet over 1 year ago in reply to CadAP
    Thank you, this is a nice example. Any plans to add something like this to the System Capture TCL documentation?
  • CadAP
    0 CadAP over 1 year ago in reply to Sermet
     Sermet  Thanks for your suggestion. I'll create sample script on the ASK(previously known as COS) portal.
    Also recommend you check ASK portal we have plenty of tcl script sample.
    https://support.cadence.com/
