  3. Allegro X Capture 23.10.006 causes Mouse to Jump to Top...
  • State Verified Answer
  • Replies 8
  • Subscribers 31
  • Views 6730
Allegro X Capture 23.10.006 causes Mouse to Jump to Top or Bottom of Screen when using "I" or Ctrl+mouse Wheel Zoom Input Command
cstocci52
cstocci52 over 1 year ago
Folks,
Has anybody experienced the Cadence Allegro X version 23.10.006 exhibit the following behavior?  When viewing any schematic and I want to zoom to a specific area of the schematic, whether I use the "I" shortcut key command or hold the Ctrl key and use the mouse wheel to zoom in or out, the mouse cursor drops to either the top or bottom of the screen.  Version 17.40 did not have this problem, but it seems that version 23.10 does.  It is not a show stopper, but a bit of a pain in the ... everytime I want to zoom in on some aspect of a schematic.
Is this a driver issue, a "quirk" with Cadence's schematic Capture, what?
CT
  • Jeet
    Jeet over 1 year ago +1 verified
    Which version of the Windows you are using, Is it Win 11 24h2? Also Can you try de-selecting Grid References from View > Grid References in OrCAD Capture?
  • cstocci52
    0 cstocci52 over 1 year ago in reply to StaticEE
    Hi StaticEE,
    I am running Windows 11 Pro 24H2 and Cadence 23.10.006 and had this issue until I unchecked the "Grid References" listing under the "View" main menu.  Now both the zoom in and out do not jump around anymore.
    However, whenever you start another schematic, it seems a default condition that checks the "Grid References" as ON.  Keep an eye on that when starting a new schematic or even, sometimes, when opening an old schematic that had that option unchecked.
    CT
  • Jeet
    0 Jeet over 1 year ago in reply to StaticEE
    Can you please try with Version 24.1 along with hotfix 3 and let me know if you are facing the same issue.
  • StaticEE
    0 StaticEE over 1 year ago in reply to Jeet
    Hi cstocci52  and Jeet ,
    I tried disabling the "Grid References" under view but it did not solve the problem for me. However, I'm only facing this during Zoom-In. No issues during Zoom-Out, the cursor stays in place.
    Unfortunately, I cannot upgrade to 24.1 as its handled by our company IT.
