  3. Library container sync issue - System capture
  • State Suggested Answer
  • Answers 1
  • Subscribers 30
  • Views 2842
JaySashidh
JaySashidh over 1 year ago
Lost sync with all the libraries that I created in system capture in 2022 and 2023 version. Even after adding them in EDIT -> Preference -> Library container the library are not getting added back to the design any solution for this.
  • JaySashidh
    JaySashidh over 1 year ago in reply to srish09 +1 suggested
    It is happening with system capture and after the 2024 version. So I Uninstalled the 2024 version and started using 2023 and 2022 version. The above problem was due to pulse server cannot keep track between…
  • srish09
    0 srish09 over 1 year ago
    What type of libraries are you working with in System Capture - DE-HDL or OrCAD libraries? Did the problem start appearing after any version/hotfix update?
  • JaySashidh
    0 JaySashidh over 1 year ago in reply to srish09
    It is happening with system capture and after the 2024 version. So I Uninstalled the 2024 version and started using 2023 and 2022 version. The above problem was due to pulse server cannot keep track between versions and I have to shut down the pulse server everytime I switch between versions and also the library container gets corrupted once I open the project in the wrong version.
