  3. Export from SysCap to layout
  • Subscribers 31
  • Views 1687
LL202506165637
LL202506165637 over 1 year ago
I have an issue while I try to export my schematic from SysCap to layout : SPMHNI 235 & SPMHNI 234. The first one says "error detected saving design", the second one "you cannot save without unlocking".
When I unlock the schematic, and go to file>export to layout, the design just lock, so I doesn't export the file. I did a first export, so I have a first brd file, I tired to rename or delete and export again but won't work.
If you have an idea on how to solve this ?
Thank you for your help :)
  • Elecguy
    0 Elecguy over 1 year ago
    Try opening the database and running dbdoctor with the options Update all DRCs including batch and Check shape Outlines activated. Save and then import the logic (or maybe export). FInally, delete temp files inside the design folder in your current working directory and, if required, reboot the system.
