  3. Starting Project from netlist, or layout
  • State Suggested Answer
  • Answers 1
  • Subscribers 32
  • Views 2634
ML202409254454
ML202409254454 over 1 year ago
I work for a design engineering firm. The way we are working right not is that we design the layout from a netlist from our client. So we basically don't have control on the schematics.
Our problem is when we generate a BOM file from the layout , we get information on the footprint and not on the actual component (PN)
I am currently trying to figure if there is a way the import a netlist to a new project to sync the layout design to a visual aid (schematic) and to link it to our local component library? I know it's a weird way to do thing, and I'm trying to simplify our design integration to the system capture flow.
Thank you
  • Robert Finley
    Robert Finley 11 months ago +1 suggested
    That approach would never work for RF designs. Design engineers choose specific passives (and equivalents to resolve availability/stock issues) during schematic capture. Your customer needs to generate…
  • avant
    0 avant over 1 year ago
    Does the customer supply an Allegro formatted netlist, or a flat netlist?
    An Allegro formatted netlist will have component information imbeded in it, which is visible with BOM creation. surely the schematic parts at least have values.
    If they won't allow access to their schematic, ask for an Allegro formatted netlist.
    Since they control the schematic, it seems like they would create a BOM? I mean, creating a schematic usually entails selecting components.
    We ran into a similar case with a customer. They were so secretive and stingy with information (even with an NDA) that we turned them away.
  • ML202409254454
    0 ML202409254454 over 1 year ago in reply to avant
    They do provide a "Allegro formatted netlist" that we change to fit in our layout "ex some pin name, having the right footprint, etc...
    The main problem is that if we generate a BOM repport from APD we only get the footprint name not the PN. We could create a new footprint for each PN. But I feel that's starting to make thing complicated for no good reasons.
    Normaly we go back and edit the BOM for each ref des match the right PN. But it can be quite long, and error prone.
    I am trying to find a way to bridge the part info into the HDL library we are setting up.
  • avant
    0 avant over 1 year ago in reply to ML202409254454
    Do you receive the three .dat netlist files? These contain component information.
    If so, do you import the netlist files using the Cadence tab?
    Sorry I cannot answer your original question.
  • Robert Finley
    0 Robert Finley 11 months ago
    Your customer needs to generate the BOMs.  Full stop.
