  3. waive the warnings in the Violation Window in system capture...
  • State Verified Answer
  • Replies 7
  • Subscribers 30
  • Views 5634
waive the warnings in the Violation Window in system capture schema
MZ20250602835
MZ20250602835 9 months ago
Dear All,
after Migrating DE-HDL Designs to Allegro X System Capture i usually get some warnings in violation window such as :
may i ask if it is possible to waive these Warnings with TCl Command or other settings under START_CANVAS instead of waive the violations manuell after each import?
Many thanks and Best Regards
Moyan
  • CadAP
    CadAP 9 months ago in reply to MZ20250602835 +1 verified
    MZ20250602835 Try below command: cps::clearViolationMessage messageType messageNumber For example, for clearing Message is DESIMP-91 cps::clearViolationMessage "DESIMP" "91"
  • CadAP
    0 CadAP 9 months ago in reply to MZ20250602835
    MZ20250602835
    Try below command:
    cps::clearViolationMessage "DSCS" "104"
  • MZ20250602835
    0 MZ20250602835 9 months ago in reply to CadAP
    Dear CadAP,
    many thanks for your reply. I already tried this command cps::clearViolationMessage "DSCS" "104" and after given this command i got the value 0.
    I tried to follow the warning Message to add a value and the warning is away. I assume that this kind of warning can't be waived without assigning a voltage value.
    Many thanks and Best regards
    Moyan
