  3. TCL/script to get the Custom variables variant specific...
  • State Verified Answer
  • Replies 10
  • Subscribers 30
  • Views 5310
TCL/script to get the Custom variables variant specific Values and transfer to a customer variable?
MZ20250602835
MZ20250602835 7 months ago
Dear all,
may i ask how could i make a TCL/script in order to get the Custom variables variant specific Values for specific row(For example row3 DOC_PART_PCBA) and then give/transfer this value to a customer variables?
Many thanks
Moyan
  • CadAP
    CadAP 7 months ago +1 verified
    MZ20250602835 Please try the script below, as it will update the custom variable value by reading from the variant. For the purpose of this example, I've taken the first value of the variable from…
  • CadAP
    0 CadAP 7 months ago in reply to MZ20250602835
    MZ20250602835
    Retrieve the list of variants from the design using the function cps::getVariantNames, which returns the variant names in order, and store this list in a variable.
    Iterate to the foreach loop defined in the above code and retrieve the variable value 'data'.  Parse the variable by removing the prefix "CV_" and then match the resulting variant name against the list from above in order to obtain the corresponding property value.
    This will help you to achieve you requirement.
  • MZ20250602835
    0 MZ20250602835 7 months ago in reply to CadAP
    Dear CadAP,
    many many thanks again, i modified the script within checkFuncVar in order to get CV_VAR_X at one time so it works independent of the order of the variants.
    happy Easter
    Many thanks
    Moyan
  • MZ20250602835
    Dear CadAP,
    during test i have one issue, if the data content ~ and changed the row in this case i can`t get the value later for custom variable.
    CV_VAR_1='DOC_COMPPLAN_DESC=test|DOC_COMPPLAN_NO=2100-1000|DOC_COMPPLAN_VER=00|~
    DOC_PART_PCBA=5100-1000|DOC_PART_PCB_NUMBER=5100|DOC_PCBAPLAN_MOD_DATE=test_MOD_~
    DATE|DOC_PCBAPLAN_MOD_ENG=test MOD_ENG|DOC_PCBAPLAN_PROD_DATE=test_DATE|DOC_PCBA~
    PLAN_PROD_ENG=test_ENG';
  • CadAP
    MZ20250602835
    Please try to remove the "~" from the list "valuesOnlyList" where we are storing the dict  key and value.
  • MZ20250602835
    Many thanks again,
    the problem is solved.
    Best Regards
    Moyan
