  3. Launching *.cpm File in System Capture via Batch File
  • State Verified Answer
  • Subscribers 32
  • Views 1653
MZ20250602835
MZ20250602835 7 months ago
Dear all,
i found the command below to open a cpm File if the project name is available.
syscap -proj <project_name>.cpm
syscap -proj <project_path>/<project_name>.cpm -tclfile <tcl file location>\<tcl_file_name>.tcl -product "<license name>" -nograph
May i ask how could i set the value in order the system capture to find the *.cpm and open it without giving a concrete project name?
Best Regards
Moyan
  • MZ20250602835
    MZ20250602835 7 months ago in reply to JCTEYSSIER0 +1 verified
    Many thanks for your reply. I set a batch file in order to set it: @echo off setlocal enabledelayedexpansion set "projectFolder=%~dp0..\..\..\.." for %%I in ("%projectFolder%") do set "projectFolder…
  • JCTEYSSIER0
    0 JCTEYSSIER0 7 months ago
    *.cpm will not be possible since you can have several cpm file in same <project_path>.
    I have already use such configuration in order to acess different version of same project
  • MZ20250602835
    +1 MZ20250602835 7 months ago in reply to JCTEYSSIER0
    @echo off
    for %%I in ("%projectFolder%") do set "projectFolder=%%~fI"
    echo %projectFolder%
    for %%f in ("%projectFolder%\*.cpm") do (
    set "file_list=!file_list! %%~nxf"
    cd %projectFolder%
    echo %file_list%
    %CDSROOT%/tools/bin/syscap -proj %file_list%  -product "PCB_design_studio"
