  3. : How to create a schematic symbol for an existing custom...
  • Subscribers 31
  • Views 490
: How to create a schematic symbol for an existing custom footprint (padstacks already built) in Allegro X 25
AT202608047036
AT202608047036 2 months ago
Hey,
I've already built the padstacks and copper layout for a custom part (an inverted-F antenna element) as a footprint in the PCB library. Now I need to create the matching schematic symbol so I can place it on my schematic page and have it map to that existing footprint.
What I've checked so far:
  • File > New only offers Project, Block, Footprint, and Template based footprint — there's no "Symbol" option.
  • Place menu has Component, Wire, Bus, Special Symbols, Schematic Block, Abstract Component, etc. — nothing for creating a brand-new symbol from scratch.
  • Tools menu has Generate BOM, Launch PCB Editor, Cadence Unified Library Generator, and Part Manager.
I tried a few menus but none worked for me.
Any help is appreciated.
  • Ulf K
    0 Ulf K 2 months ago
    I cannot answer how this is done in System Capture as I do not have a license for that tool.
    Schematic symbols are not created in the layout editor. It is done in the schematic editor.
    For the Capture tool, the procedure is as follows:
    (First open the layout editor and note the name/number of any pins in the symbol.)
    Open your .OLB (library) from there add/create new part.
    When in the schematic editor, draw whatever graphic you desire.
    Add pins and name them with their respective names/numbers.
    Define the footprint in the properties column. Save and exit.
