  2. Allegro X Capture CIS
  3. Can't open BOM file with Excel
  • Replies 7
  • Subscribers 45
  • Views 9015
Hossein1357
Hossein1357 over 11 years ago
I am using OrCad 16.6 and I have a problem with it. When I try to generate BOM file one of important options is not active. As it is in below picture you see that I can't choose "Open in Excel" option.
I would appreciate any help,
Hossein
  • oldmouldy
    0 oldmouldy over 10 years ago
    Check out the past posts on this, you can either "View Output" and open the BOM in the application associated with the BOM file extension OR "Open in Excel", if you uncheck the "View Output" option the "Open in Excel" option will activate.
  • ichliebedich
    0 ichliebedich over 5 years ago in reply to oldmouldy
    Thank you! I solved this problem
  • ichliebedich
