  2. Allegro X Capture CIS
  3. Change multiple off-page connectors names & directions
  • Subscribers 53
  • Views 13210
vicvicvar
vicvicvar over 9 years ago
Hi Forum ,
I have a set of off-page connectors as follow
I want to change the names and directions from a spreadsheet (Similar to export/import properties) . If I Ctrl+E the off-pages connectors I get the following
How can I export/import the last table ? Since I have ~200 off-page connectors , I rather manipulate them from a spreadsheet
  • steve
    steve over 9 years ago +2
    There is a free OrCAD App called EDAis CoolEdit Box that allows you to group select ports / off page connectors and change them to a different type. Take a look at orcadmarketplace.com/.../Default.asp…
  • B Bruekers
    0 B Bruekers over 9 years ago
    you can use the ctrl-insert to copy the column, and shift-insert to paste it again. However, you are only allowed to change the name. You cannot edit the location and direction.
    An idea is to place the correct offpage connectors next to the ones you want to change and then copy/paste the names from the old to the new connectors.
    Another way is to implement a TCL script which replaces each offpage connector with a different type. I know it can be done, just don't ask me how.
  • steve
    0 steve over 9 years ago
    There is a free OrCAD App called EDAis CoolEdit Box that allows you to group select ports / off page connectors and change them to a different type. Take a look at orcadmarketplace.com/.../Default.aspx
    • Vote Up +2 Vote Down
  • vicvicvar
    0 vicvicvar over 9 years ago
    Thanks Steve, I'll give it a try.
  • stigskov1
    0 stigskov1 over 5 years ago in reply to vicvicvar
    store.ema-eda.com/.../
