  2. Allegro X Capture CIS
  3. Defining Custom Shortcut Keys on OrCAD Capture CIS v17....
  • Replies 7
  • Subscribers 46
  • Views 16590
Defining Custom Shortcut Keys on OrCAD Capture CIS v17.2
Gelo M
Gelo M over 4 years ago
Good day!
I'm currently using Cadence OrCAD Capture v.17.2.
Is there a way to bind custom keyboard shortcuts to functions accessible through mouse clicks?
For instance, I'd like to map "Signals" as shown below to, say, CTRL + ALT + S:
Signals
Thanks in advance!
  • tennywhy
    0 tennywhy over 4 years ago
    i have do it , my be you could reference code below
    # asume shortcut key set as Ctrl+W
    proc shortcutSetInit { } {
    set shortCutArray {
    {"select Entire Net" "Ctrl+W" {MenuCommand "14844"}}
    shortCutSetAll $shortCutArray
    proc shortCutSetAll { LshortCutArray } {
    #puts "gos scs do"
    set shortCutArray $LshortCutArray
    set shortCutLength [llength $shortCutArray]
    for {set i 0} {$i < $shortCutLength} {incr i} {
    set shortCutElement [lindex $shortCutArray $i]
    shortcut_RegisterActions $shortCutElement
    proc shortcut_RegisterActions { shortCutElement } {
    set lEnableDS 1
    set shortcutName [lindex $shortCutElement 0]
    set shortCut [lindex $shortCutElement 1]
    set shortCutCommand [lindex $shortCutElement 2]
    set enable $lEnableDS
    RegisterAction $shortcutName "::shortcutSet::shortcut_Enabler" \
    $shortCut $shortCutCommand "Schematic"
    proc ::shortcutSet::shortcut_Enabler {} {
    # Get the selected objects
    set lEnableDS 1
    return $lEnableDS
    shortcutSetInit
  • Gelo M
    0 Gelo M over 4 years ago in reply to tennywhy
    Hi Tenny,
    Much thanks for your reply.
    I have other questions:
    1. Where do I locate the file which I will edit to include the reference code?
    2. Is there a list of commands possible for remapping?
      For example, MenuCommand "14844".
      If I want to make a new shortcut for another command, how do I know which menu command number/ index to use? (ex: "14844")
  • tennywhy
    0 tennywhy over 4 years ago in reply to Gelo M
    1. you should rename the file  shortcut.tcl. and put it in capautoload directory
    2. you should turn on the command display in command window use follow command , then you will see the menucommand when you operate.
    SetOptionBool Journaling TRUE
    SetOptionBool DisplayCommands TRUE
    • Vote Up +2 Vote Down
  • Gelo M
    Thanks Tenny!
    I have set both Journaling and DisplayCommands to TRUE and now able to see corresponding MenuCommand indexes, like "14844" when using the "Signals" function.
    I created a file named shortcut.tcl under the folder C:\Cadence\SPB_17.2\tools\capture\tclscripts\capAutoLoad
    But I get the following error at startup of Capture CIS:
    Loading C:/Cadence/SPB_17.2/tools/capture/tclscripts/capAutoLoad/shortcut.tcl
    Error loading C:/Cadence/SPB_17.2/tools/capture/tclscripts/capAutoLoad/shortcut.tcl: invalid command name "proc ::shortcutSet::shortcut_Enabler"
    while executing
    "proc ::shortcutSet::shortcut_Enabler {} {
    set lEnableDS 1
    return $lEnableDS
    (file "C:/Cadence/SPB_17.2/tools/capture/tclscripts/capAutoLoad/shortcut.tcl" line 34)
    invoked from within
    "source $lFile"
    Here is line 34 of shortcut.tcl:
    Screenshot
    Thanks again in advance.
  • SimonLym
    0 SimonLym over 1 year ago in reply to Gelo M
    Look like namespace issue.
    Add below at the begin of .tcl file.
    namespace eval ::capMenuUtil {}
    Update: Don't try this way, capture22.1 crash everytime when i press ctrl +W.
