  2. Allegro X Capture CIS
  3. Parts Manager BOM replaces all fields with "Do Not Stuff...
  • Subscribers 44
  • Views 3439
Parts Manager BOM replaces all fields with "Do Not Stuff"
MRL Kevin
MRL Kevin over 3 years ago
Is there a way to generate a BOM with parts manager and only show "Do Not Stuff" in a "Mounting Status" column rather than replacing all fields with "Do Not Stuff"?
I would like the report to show the Quantity, Value, Description, PCB Footprint, Manufacturer, and Manufacturer PN values.
Thanks for any help!
  • rg13
    0 rg13 over 3 years ago
    Enter following command in Capture's command window:
    SetOptionString CisBomDisplayPartNumberForDNS TRUE
    Now create CIS variant BOM. You should be able to see part number for DNS parts in CIS variant BOM.
  • rg13
  • briwei
    0 briwei over 3 years ago in reply to rg13
    This didn't seem to work for me.
    The Command Window accepted the command as valid, but there was no change to the resultant BOM spreadsheet. It still looked like OP's example with all the fields replaced with "Do Not Stuff". I tried generating the BOM both from the Part Manager, right-clicking on the variant, Reports>StandardBOM, and I also tried generating the BOM through the top menu Reports>CIS Bill of Materials>Standard. I also tried closing and re-opening Allegro DE CIS to see if the command needed to a restart to take effect.
    None of these seemed to work, and each time, the generated BOM looked like OP's example.
    Any other ideas?
