  2. Allegro X Capture CIS
  3. OrCAD Capture: Advance Annotation function
  • State Verified Answer
  • Replies 7
  • Subscribers 52
  • Views 14889
yywhy
yywhy over 4 years ago
Hello forum,
Anyone knows how do I activate the advance annotation function?
Please help
  • DS1995
    DS1995 over 4 years ago +1 verified
    It seems like you are trying to do advanced annotation on a Pspice schematic project type. Advanced annotation will only appear in this dialogue box for PCB schematic design. Select File > New > Schematic…
  • DS1995
    DS1995 over 4 years ago in reply to mdabdi +1
    Hi, If you do not want to create a combined netlist of all the folders, then that means these folders have no relation with each other from the design/Board perspective. (As per my understanding - that…
  • DS1995
    +1 DS1995 over 4 years ago
    Advanced annotation will only appear in this dialogue box for PCB schematic design. Select File > New > Schematic and you will see the advanced annotate option or in the current project select the DSN file in the project manager and Right mouse click > Change project type > Schematic.
  • yywhy
    0 yywhy over 4 years ago in reply to DS1995
    Thank you! It worked. Another question.. Why does it not show the other folders but just the rooted folder?
  • DS1995
    0 DS1995 over 4 years ago in reply to yywhy
    It seems like your implementation of the hierarchies is a bit different.
    In my opinion, the only reason to create schematic folders other than ROOT is to call those schematic folders inside ROOT as Hierarchical blocks. Once these other schematic folders are called inside the ROOT schematic, you will be able to see those as a part of the hierarchy in this dialogue box.
  • oldmouldy
    0 oldmouldy over 4 years ago in reply to yywhy
    It looks like there are no hierarchical blocks in the MB Schematic Pages that reference the S<n> folders, hence they are not part of the "root" design and cannot be annotated.
  • mdabdi
    0 mdabdi over 4 years ago in reply to oldmouldy
    Hi, I have the same issue. The reason why there are several folders created is due to creating of netlist. Netlist can only be created for the "rooted" folder. I have several sub boards that I need to generate the netlist. Combining all my MB - S7 schematic pages will yield a whole netlist which cannot be separated when doing layout, as such I have created folders to indicate they are of different sub-boards.
