  2. Allegro X Capture CIS
  3. OrCAD - Tip of the Week: Graphical locking of objects you...
  • Subscribers 42
  • Views 1942
OrCAD - Tip of the Week: Graphical locking of objects you do not want to be changed
DesignTech
DesignTech over 3 years ago
Does your design also have a central IC around which all the connections are to be done? And so, you don’t want the IC to move even a grid. You want that the IC should be fixed in its place, making it easy for you to draw wires from it to other part pins.
Graphical locking in Capture allows you to do just that. Right-click on any part and select ‘Lock’ to lock that part from moving on the page.
You can even lock a page, schematic folder, or even the entire design if needed. All the parts in the locked page, folder, or the design get locked.
You can still add or delete properties from locked parts.
Team DesignTech
Cadence Design System
  • tennywhy
    tennywhy over 3 years ago
    how to only lock the net alias  in page ?
  • tennywhy
    tennywhy over 3 years ago in reply to tennywhy
    I mean wires and the aliases on wire together also cannot be locked, but can be locked on a full page.
    How is this done? lock alias and wires is a usefull function
  • AyushD
    AyushD over 3 years ago in reply to tennywhy
    currently locking wires and alias does not work
