  2. Allegro X Capture CIS
  3. Unable to place some parts with CIS. "ORCIS-6085"
  • Subscribers 44
  • Views 2836
bbradley
bbradley over 3 years ago
This is very frustrating and I have no way to move forward using this tool with this error.
I have everything setup and it works with 90% of components, but no matter what I do, some components simply will not work.
Trying to place the component directly through the database results in an OS error: "Windows cannot find [PART NUMBER]. Make sure you typed the name correctly and then try again" which make no sense, and the OrCAD error: "ERROR(ORCIS-6129): The specified file was not found"
I am able to manually place the part from the library fine without using the database manager, but trying to link it results in "WARNING(ORCIS-6085): Could not read part information from [Schematic Part name]"
These errors are completely unhelpful and I have been stuck on them all day.
Edit: Finally figured it out. Some path got messed up in my ini file. I am not sure why some components were still working fine. Fixing that seems to have resolved it.
  • DenzilPenberthy
    0 DenzilPenberthy over 3 years ago
    Hi, I'm having this same problem.   Do you know which path was wrong? Or can give me any hints on what to check in the .ini file?
    Cheers.
  • DenzilPenberthy
    Cheers.
  • MarkLu
    0 MarkLu over 2 years ago in reply to DenzilPenberthy
    Cheers.
