  2. Allegro X Capture CIS
  3. Unable to generate netlist due to a part missing pin er...
  • Subscribers 44
  • Views 8039
Unable to generate netlist due to a part missing pin error
Neil mustafa
Neil mustafa over 3 years ago
I am trying to make modifications to my schematic and the board I already designed for it. So, I haven't made any changes yet but for some reason I cannot generate a netlist for the current schematic. This is what I get:
------ Oversights/Warnings/Errors ------
#1 ERROR(SPMHNI-191): Device/Symbol check error detected.
ERROR(SPMHNI-195): Symbol 'SOT89' for device 'MOSFET_N_GDSD_SOT89_TN2510N8-G' is missing pin '4'.
------ Library Paths ------
MODULEPATH = .
C:/Cadence/company/pcb/modules
PSMPATH = .
symbols
padstacks
C:\Cadence\company\pcb\padstacks
C:\Cadence\company\pcb\padstacks\student
C:\Cadence\company\pcb\padstacks\smartstart
J:/CADENCE/LIBS/PCB/PADS/
C:/Cadence/SPB_17.2/share/pcb/pcb_lib/symbols/
C:/Users/nmustafa/Custom_Symbols/
J:/CADENCE/LIBS/
J:/CADENCE/LIBS/SCH/LAP TEMPLATES/
J:/CADENCE/LIBS/PCB/SYMBOLS/SMT
J:/CADENCE/LIBS/PCB/SYMBOLS/THRU_HOLE
J:/CADENCE/LIBS/
PADPATH = .
symbols
padstacks
J:/CADENCE/LIBS/
------ Summary Statistics ------
#2 Run stopped because errors were detected
netrev run on Sep 27 12:32:58 2022
DESIGN NAME : '0207501_SCH'
PACKAGING ON Mar 2 2016 00:37:24
COMPILE 'logic'
CHECK_PIN_NAMES OFF
CROSS_REFERENCE OFF
FEEDBACK OFF
INCREMENTAL OFF
INTERFACE_TYPE PHYSICAL
MAX_ERRORS 500
MERGE_MINIMUM 5
NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
NET_NAME_LENGTH 24
OVERSIGHTS ON
REPLACE_CHECK OFF
SINGLE_NODE_NETS ON
SPLIT_MINIMUM 0
SUPPRESS 20
WARNINGS ON
2 errors detected
No oversight detected
No warning detected
cpu time 0:01:20
elapsed time 0:00:01
INFO(ORCAP-32005): *** Done ***
Now, looking at the part in question, it does indeed have 4 pins, so I am not sure what they mean by Pin 4 is "missing" or how to fix that.
Here is the Symbol the software is complaining about:
Here is the schematic that includes this part , with REF DES Q7
If there is anything else you need please let me know, your help is highly appreciated!
  • oldmouldy
    0 oldmouldy over 3 years ago
    Quite likely, the SOT89 footprint has 3 pins (1,2,3) and you are trying to map a 4 pin Schematic Part to it. You will need to use a Footprint with 4 pins (1,2,3,4) for this to work.
  • Neil mustafa
    0 Neil mustafa over 3 years ago in reply to oldmouldy
    Here is the SOT89.DRA file that is on my system. From what I am seeing it has 4 pads. Any thoughts of what else could be causing this?
    All the parts that are in this schematic are database parts just like the one in question above.
  • oldmouldy
    0 oldmouldy over 3 years ago in reply to Neil mustafa
    There is a SOT89 in the Cadence provided libraries that is a 3-pin part. Check that the padpath and psmpath User Preferences have your library folders above the provided library folders. (The folder search order is also listed in the netrev.lst file which is usually in the same folder as the board file)
