  2. Allegro X Capture CIS
  3. OrCAD Tip of the Week: Sync changes across hierarchy
  • Subscribers 42
  • Views 7138
DesignTech
DesignTech over 2 years ago
Hierarchical designs reduce a lot of repetitive work. They help repeat a circuit multiple times in designs with little to no effort.
However, with hierarchy, you need to be certain that changes in the referenced design are updated in the top-level designs. Manual verification of such changes is cumbersome. And regenerating the hierarchical block every time referenced design changes is also not an effective work model.
So, an automated way to synchronize these changes is of great help. OrCAD Capture offers just that. Synchronize Up/Down options on hierarchical blocks lets you synchronize your block with respect to the referenced design or vice versa.
You can even update the changes across all duplicate hierarchical blocks by using the Synchronize Across option.
Team DesignTech
Cadence Design Systems
  • Adam
    Adam 8 months ago
    Hello
    Synchronize Across do nothing on my Orcad X.
    There is a way to Synchronize Up multiple hierarchical blocks ? I do not find any way to do that...
