  2. Allegro X Capture CIS
  3. PDF export disappeared from menu and other weird proble...
  • State Suggested Answer
  • Answers 1
  • Subscribers 43
  • Views 6272
PDF export disappeared from menu and other weird problems
xkumpu
xkumpu over 2 years ago
I started to have weird problems with OrCad some days ago. The first sympthom was inability to modify an existing library. Then I updated to the latest 17.4 revision, but it didn't help.
The other problems I have detected:
-  File -> Export no more has PDF option
-  Options-> Extended preferences doesn't open any dialog
- Layout update always fails with error:
#1 ERROR(SPMHNI-235): Error detected saving design.
ERROR(SPMHNI-234): Cannot write drawing, 'd:/projects/path_to_my_my_project/#Taaaacm26496.tmp' out to the directory: 'Database has a non-recoverable corruption. Contact Cadence Customer Support with the design file and the details of the last steps performed.'.
However, I can open the .brd file without problems and edit it.
I have tried also with my old projects, and the result is the same: I can't update the layout (.brd file) from Capture any more.
My platform is Windows 10 Pro,  OrCad Capture CIS + OrCad PCB Designer Professional.
Has anyone seen this kind of problems ..?
  • rg13
    0 rg13 over 2 years ago
    I found one article related to ERROR(SPMHNI-234): Cannot write drawing on Cadence online support portal. Link of which you can find as follows:
    Article (11630942) Title: When importing logic on board file, get an error message "ERROR(SPMHNI-234): Cannot write drawing"
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nbthEAA
  • rg13
