  2. Allegro X Capture CIS
  3. CIS Database Part - Ordering
  • Subscribers 44
  • Views 2856
jmh299
jmh299 over 2 years ago
I am building my CIS database through CIP.  Is there any way to order the way the separate sections are ordered?  As a hypothetical example my tables look something like this:
Capacitors
ICs - Transceivers
Power Supplies - On-Board
Inductors
ICs - MCUs
Is there anyway to rearrange them such that they are presented in the following order?
Capacitors
Inductors
ICs - Transceivers
ICs - MCUs
Notice I am using ICs - Transceivers as a top level folder, but this is because in CIP I want custom parametric tables so I can associate relevant information with each section.  An example being a "memory" field for MCUs, if I lumped both Voltage Regulators and MCUs underneath ICs there would be a memory field for Voltage Regulators which I don't particularly want to be present.
  • RFinley
    0 RFinley over 2 years ago
    A beautiful feature of CIP is it is built to show SQL Table Views, a subset of the Capacitor table fields.
    In CIP (logged in as admin).  Admin pulldown>  Configuration> Component Views Tab>
    You can create multiple Views of the ICs or Misc table having a subset of properties visible to CIS part browser.
    CIP allows you to create a CSV list to subdivide a table.   Bulk Operations>  Component View Mover> ...  import the list.
    IMHO, I manage more than 6K part records.
    Custom ICs we sell are subdivided from the rest of the ICs.  But, I have made extra effort to create specific tables to help engineers go "part shopping".  Ultimately, engineers shop using DigiKey first (can't get the part, why bother?) and eventually, slowly reverted to just using one ICs table.  Worse, if the part doesn't land in "Unassigned", my guys can't find it.
    Deal with mostly RF designs.  The Misc table is split between etch parts/patterns (Wilkinson combiner, directional couplers, transitions) and physical components (ceramic filters, shield cans, standoffs, batteries, microphones, light pipes, speakers.)
    Haven't had specific tables pay off except a flatter hierarchy is faster to navigate for new coworkers.
    Don't know what to tell you about the sequence.  It is crazy easy to write your SQL query to report fields sorted alphabetically.
    Don't think that will change.
  • jmh299
    0 jmh299 over 2 years ago in reply to RFinley
    So you have resorted back to a singular ICs table with a folder navigation structure such as:
    RS-485 transceiver in ICs with part type “Transcievers/RS-485”?
    Thus the navigation structure in CIS looks like
    ICs
       +Transcievers
           Rs-485
    ? or something similar?
    my only is is the parameter table than brings little benefit as the parameter table is for the top level folder “ICs” so there may be many parametric fields left unfilled or meaningless.  But reading into your response, I think you are suggesting people shop on Digi-Key anyways for specific parameters if a short dig in the database doesn’t do the trick.
    thanks for the response!
  • RFinley
    0 RFinley over 2 years ago in reply to jmh299
    I forgot about PartType property allowing you to group parts together by type.  It was surreal to land a contract for a company having thousands of MPNs in a single ICs table.
    The best part is you can change/optimize PartType in CIP without (shouldn't) any effect on your sch DSN files
    (you could cache this in the sch DSN with the DBC file.  But, please don't.)
  • jmh299
    Wow would be difficult to find parts with only a single ICs table, I guess queries would come in handy.
    but back to the root the parametric table is just sort of out the window having one ICs table?  Just rely on designers to pull up Digi-Key anyway to find relevant parametric?
  • RFinley
    CIP extracts extra data that you won't want to circle back to add in the future.  It doesn't hurt anything.
    I like the CIP/Silicon Expert plugin.  We're not at that point yet.
