  2. Design Entry HDL
  3. Sectioning in DE HDL
  • Subscribers 24
  • Views 16439
admin
admin over 13 years ago
Hi, a newbie 's question. What does sectioning do in DE HDL?
So far I only learnt that sectioning a part can display the pin numbers of all the pins of that particular part, and of course a psm must be mapped to that part symbol initially.
Thanks in advance.
  • Jerry GenPart
    0 Jerry GenPart over 13 years ago
    You're correct, the DEHDL Section command will add the part's pin numbers to its pin stubs. However, the preferred method of seeing the pin numbers is to run Export Physical and insure the back annotation option is enabled. This will add pin numbers to all the parts in the entire design.
     Using the Section command, while it does display pin numbers, will "fix" those pin numbers so that the PCB designer will not be able to swap gates within a footprint. Essentially, you're conveying that you don't want those pins to be swapped. This is why you should only use the Section command if you want to prevent pin swapping. The PCB designer does have an override capability, but it's not often used.
  • admin
    0 admin over 13 years ago
    Hi Jerry,
    Thanks for the reply. Just for a better understanding,
    say I have two pins U1.1 and U1.2 are supposed to be connected to the two input pins of a NOR gate: U2.1 and U2.2. (e.g U1.1 to U2.1 and U1.2 to U2.2),
    of course it would also be right if U1.1 is connected to U2.2 and U1.2 to U2.1. (U1.1 and U1.2 swap)
    by sectioning U1 -> "fixing" U1,  U1.1 will be mapped to U2.1 and U1.2 to U2.2 when the schematic is exported to PCB Editor (re-packaged).
    am I right to interprete like this?
  • Jerry GenPart
    You can make the wire connections to the pins on each part however you want. All the Section command does is to prevent the swapping of pin numbers.
  • admin
    Hi Jerry, I got it. Thanks again for the help.
  • CJC147
    0 CJC147 over 6 years ago in reply to Jerry GenPart
    Does anyone know there is a way to 'SECTION' all parts in a design? Even I did "Export Physical ", some parts are still not showing any section pin numbers. What could be issues causing this? library? How to fix it?
