  2. Design Entry HDL
  3. Component RefDes / page number problem - Allegro Design...
  • Subscribers 25
  • Views 7638
Component RefDes / page number problem - Allegro Design Entry HDL (17.2-2016)
skus
skus over 8 years ago
In the schematic, I use the code below for Ref Des Pattern to assign refdes according to their corresponding page numbers.
($PHYS_DES_PREFIX)($PHYS_PAGE)[0-9](01) or
($PHYS_DES_PREFIX)($PAGE)[0-9](01)  - i don't know the difference to be honest but they both work.
I am not sure if that's a correct approach but it usually works. There is one exception. If I copy or cut some components from another page and paste them to a new page, with this code, sometimes the refdes is assigned with their previous page numbers but not with their current one. How can I fix this?
thanks
  • S0undman99
    0 S0undman99 over 8 years ago
    I think that the key is that you have to do a "Save Hierarchy" before you package. What that does is it will basically re-save the instances of the components you copied to that specific page. Nothing 'wrong' with not doing that Save Hierarchy, it just doesn't do a full save of all the details to all the schematic pages.
    FYI, I use the second example there (just $PAGE), and it works great.  I believe that's what is in the help guides and such too.  Also, I think that PHYS_PAGE will be different than PAGE if you were to start adding pages and/or moving pages from one place to another in your design.
    Also, a trick, if you want to "override" the page, then you can add a property to the components called "PAGE", and the packager will take that.  So, like when we went to a 10-page schematic once, I took all the components on page 10 and gave them a "PAGE" property with the value set to "A", so I would get UA01 and UA02 (I basically told Concept that i wanted this to be page "A")
  • skus
    0 skus over 8 years ago in reply to S0undman99
    Thanks for the recommendations. I tried "Save Hierarchy" but it didn't work. I also tried adding a custom property named "PAGE". But it didn't work either. Cadence still uses the old page number.
    I tried something else. I changed the code like this:
    ($PHYS_DES_PREFIX)($MADEUP)[0-9](01)
    I added a property named $MADEUP. I assumed it will take the variable under $MADEUP but it still uses the old page number in the refdes! I really don't understand how or why it is happening.
  • S0undman99
    0 S0undman99 over 8 years ago in reply to skus
    are you using the "Repackage" option when you are running the export physical command?  You may need to reset to "$LOCATION=?" and then use the repackage option.  if that doesn't work, then I"m sorry, but I don't know what's happening, and I would reach out to Cadence support.
  • skus
    Yes I use "repackage" option and reset the $LOCATION to ? via global property change. I will try to reach Cadence support. Thanks for the help!
  • Raam PCB
    0 Raam PCB over 6 years ago in reply to skus
    Hi, go to view / console window, on console window enter "hier_write -forcereset" and hit enter. the hierarchy page will get reset and saved. keep file backup before you do this procedure.
