  2. Design Entry HDL
  3. DE HDL Part Manager Export
  • Subscribers 25
  • Views 13934
Avers08
Avers08 over 6 years ago
Hello!
Does anyone know a simple way to export the Part Manager info in DE HDL? I have a circuit with multiple module blocks and would like to create a master bill of materials for the modules.  I see that the Part Manager has all of the information I need to do this, but so far I have been able to extract the data automatically.
Thanks in advance!
  • Jerry GenPart
    0 Jerry GenPart over 6 years ago
    Hmm... Wouldn't the BOMHDL utility provide the same data? You can easily customize the columns and property data you'd like to report. The output format can be .txt, .csv, or .html.
  • Avers08
    0 Avers08 over 6 years ago in reply to Jerry GenPart
    Thanks Jerry for your feedback!
    Currently, I don't have a property for the data I need. I have a schematic with multiple cell blocks and I'd like to report out which cells use the parts in the BOM.  When I select a part in the cell block circuit, there isn't a property with that info, unless I add it for that individual part.  I'd like to have a property called "Where_Used" and in the BOM it would list the cell block name for each part, in a similar way as the "BOM_INST" property (Ref Des).  Is there a property similar to "BOM_INST" that is used for cell blocks?
