  2. Design Entry HDL
  3. Error: PXL failed. Unable to package the design.
  • Subscribers 25
  • Views 16944
TomChen1228
TomChen1228 over 6 years ago
I want to export physical, but appeared "Error: PXL failed. Unable to package the design.".
Could you help to check it? Please refer to attached file "pxl.txt"
Thank you.
Fullscreen 6165.pxl.txt Download
    Cadence Design Systems, Inc.
    Packager-XL 17.2-2016 S055 (3790190) WIN32 5/11/2019 12:00:00 IST
    (C) Copyright 1994, Cadence Design Systems, Inc.
    Run on Wed Apr 22 13:22:33 2020
 *  Processing project file and command line  *
    ANNOTATE  'BODY' 'PIN'
    COMP_DEF_PROP  'ALT_SYMBOLS' 'JEDEC_TYPE' 'NC_PINS' 'MERGE_NC_PINS'
                   'POWER_GROUP' 'POWER_PINS' 'MERGE_POWER_PINS' 'PINCOUNT'
    COMP_INST_PROP  'GROUP' 'ROOM' 'REUSE_INSTANCE' 'REUSE_ID' 'REUSE_NAME'
                    'SIGNAL_MODEL' 'DEFAULT_SIGNAL_MODEL'
                    'VOLT_TEMP_SIGNAL_MODEL' 'SYMBOL_EDITED'
                    'INCLUDE_IN_RF_TOPOLOGY' 'NO_XNET_CONNECTION'
                    'EMBEDDED_PLACEMENT' 'ASI_MODEL' 'ISRFELEMENT'
                    'RFELEMENTTYPE' 'RFLAYER' 'RFLAYER1' 'RFLAYER2' 'RFLAYER3'
                    'RFLAYER4' 'RFLAYER5' 'RFLAYER6' 'RFLAYER7' 'RFLAYER8'
                    'RFLAYER9' 'RFLAYER10' 'RFLAYER11' 'RFLAYER12' 'RFLAYER13'
                    'RFLAYER14' 'RFLAYER15' 'RFLAYER16' 'RFCOUPLINGMODE'
                    'RFFLIPMODE' 'RFANGLE' 'RFANGLE1' 'RFWIDTH' 'RFWIDTH1'
                    'RFWIDTH2' 'RFWIDTH3' 'RFWIDTH4' 'RFWIDTH5' 'RFWIDTH6'
                    'RFWIDTH7' 'RFWIDTH8' 'RFWIDTH9' 'RFWIDTH10' 'RFWIDTH11'
                    'RFWIDTH12' 'RFWIDTH13' 'RFWIDTH14' 'RFWIDTH15' 'RFWIDTH16'
                    'RFLENGTH' 'RFLENGTH1' 'RFLENGTH2' 'RFLENGTH3' 'RFLENGTH4'
                    'RFLENGTH5' 'RFLENGTH6' 'RFLENGTH7' 'RFLENGTH8' 'RFSPACING'
                    'RFSPACING1' 'RFSPACING2' 'RFSPACING3' 'RFSPACING4'
                    'RFSPACING5' 'RFSPACING6' 'RFSPACING7' 'RFSPACING8'
                    'RFSPACING9' 'RFSPACING10' 'RFSPACING11' 'RFSPACING12'
                    'RFSPACING13' 'RFSPACING14' 'RFSPACING15' 'RFOFFSETX'
                    'RFOFFSETY' 'RFRADIUS' 'RFDEPTH' 'RFFREQUENCY'
                    'RFMITERFRACTION' 'RFBENDMODE' 'RFNUMBERLEGS'
                    'RFNUMBERPAIRS' 'RFNUMBERTURNS' 'RFCAPACITANCE'
                    'RFRESISTANCE' 'RFINDUCTANCE' 'RFPADSTACKNAME'
                    'RFPADSSMNAME1' 'RFPADSSMNAME2' 'RFPADBEGINLAYER'
                    'RFPADENDLAYER' 'RFPADLINEWIDTH1' 'RFPADLINEWIDTH2'
                    'RFPADDIAMETER' 'RFPADDIAMETER1' 'RFPADDIAMETER2'
                    'RFPADLENGTH1' 'RFPADLENGTH2' 'RFHOLEDIAMETER' 'RFPADANGLE'
                    'RFDRANAME' 'RFPADTYPE' 'RFUID' 'RFBLOCK' 'RFDCNET'
                    'RFGROUP' 'MWO_NAME'
    ALLOWED_GLOBAL_SHORTS  'VCC_SRC_FET,VCC12V'
    SUPPRESS_GLOBAL_SHORT_CHECK OFF
    DEBUG    0
    DEFAULT_PHYS_DES_PREFIX U
    FEEDBACK  'OFF'
    MAX_ERRORS 999
    NET_NAME_CHARS   @  -  !  #  %  &  (  )  *  .  /  :  ?  [  ]  ^  _  `  +
                     =  >  0  1  2  3  4  5  6  7  8  9
    NET_NAME_LENGTH 62
    NUM_OLD_VERSIONS 3
    OPTIMIZE OFF
    REUSE_REFDES OFF
    OPF_OPTIMIZATION OFF
    HARD_LOC_SEC OFF
    FORCE_PTF_ENTRY OFF
    REGENERATE_PHYSICAL_NET_NAME OFF
    SCH_POWER_GROUP_WINS_OVER_PPT OFF
    NULL_OPT_VALID OFF
    USE_VECTOR_NOTATION OFF
    FILTER_ECS_FROM_XNET ON
    OUTPUT  'ON'
    PACKAGE_PROP  'GROUP' 'ROOM'
    PART_TYPE_LENGTH 62
    REF_DES_LENGTH 300
    REPACKAGE OFF
    ELECTRICAL_CONSTRAINTS ON
    OVERWRITE_CONSTRAINTS OFF
    RUN_DIR ./worklib/adas_mpsoc_fx806dv/packaged/
    STRICT_PACKAGE_PROP  'REUSE_INSTANCE'
    USE_LIBRARY_PPT ON
    USE_STATE ON
    WARNINGS ON
    LIBRARY  'adas_mpsoc_fx806dv_lib' 'resistor' 'filter' 'osc_cryst'
             'switch_relay' 'capacitor' 'ic_interface' 'diode_led' 'transistor'
             'connector_pre' 'discrete_pre' 'inductor' 'connector' 'ic_digital'
             'ic_power' 'ic_pre' 'flyslice' 'standard' 'ut_standard' 'discrete'
             'analog' 'clocks' 'digital' 'electro_mechanic' 'logic' 'mechanic'
             'memory' 'nv_standard' 'power_supply' 'yibo'
    CDSPROP_FILE
    VIEW_PTF part_table
    VIEW_PACKAGER packaged
    VIEW_CONSTRAINTS sch_1
    DESIGN_LIBRARY adas_mpsoc_fx806dv_lib
    DESIGN_NAME adas_mpsoc_fx806dv
    VIEW_CONFIG_PHYSICAL cfg_package
    SD_SUFFIX_SEPARATOR _
    STOP_PST_GEN_ON_PTF_MISMATCH ON
    IGNORE_PRIM_BINDING OFF
    LOG_INST_PHYS_PATH ON
    ANNOTATE_VISIBLE_SEC OFF
    PTF_MISMATCH_EXCLUDE_INJ_PROP  'ALL'
    IMPORT_HFS_HARDSEC_ON_SWAP_PINS OFF
    ALLOW_PTFVALUE_INITIAL_BLANKS ON
    PRESERVE_UNSUBSTITUTED_MACROS OFF
    DETECT_SYS_NETSHORTS_PKG ON
    PROCESS_PIN_SHORT_PROP OFF
    STOP_PACKAGE_ON_SCHEMATIC_ERROR OFF
    LOCK_FILE_PERM 444
    LOCK_FOR_SAME_USER OFF
    ERROR_ON_MISMATCHED_INTERFACE ON
    RETAIN_ZERO_NODE_NETS OFF
    IGNORE_ERR_EMPTY_LONGPARTNAME OFF
    ERROR_ILLEGAL_QUOTE_PPT OFF
    B2F_OVERWRITE_CONSTRAINTS OFF
    ERROR_ON_PARTIAL_INSTANTIATION_OF_HSS OFF
    RUN_HIERWR_BEFORE_PXL OFF
    IMPORT_CONSTRAINTS_ONLY_FEEDBACK OFF
    REPORT_NET_PROP_CONFLICT_AS_ERROR OFF
    CHECK_PACK_SYNC_ON_PKG OFF
    ERR_OK_NET_ONE_PIN_MULTI_NODES OFF
    ALLOW_PINTEXT_SWAP ON
    SHOW_EXTENDED_HELP ON
    HONOR_SOFT_PROPS_PACKAGE  'NONE'
    ALLOW_SAME_PACKAGE OFF
 *  End processing project file and command line  (00:00:00)  *
Creating Configuration "cfg_package" for Design "adas_mpsoc_fx806dv"
INFO(SPCODD-181): Loading C:\Cadence\SPB_17.2\share\cdssetup\cdsprop.tmf.
      INFO(SPCODD-181): Loading C:\Cadence\SPB_17.2\share\cdssetup\cdsprop.paf.
 *  Loading the design database  *
INFO(SPCODD-181): Loading ./archive_libs/resistor/resistor/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/capacitor/capacitor/part_table/part.p~
	tf.
      INFO(SPCODD-181): Loading ./archive_libs/filter/bead_ferrite/part_table/part.p~
	tf.
      INFO(SPCODD-181): Loading ./archive_libs/diode_led/led2/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/osc_cryst/oscillator4/part_table/part~
	.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/switch_relay/dsw8/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/epcq1024l_pre/part_table/par~
	t.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/capacitor/capacitor_pol/part_table/pa~
	rt.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/inductor/inductor_power/part_table/pa~
	rt.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/ut_standard/tp/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/tps54618/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/txs0108epw/part_table/part.p~
	tf.
      INFO(SPCODD-181): Loading ./archive_libs/discrete/led/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/transistor/mosfet3_n_b/part_table/par~
	t.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/tps82130sil/part_table/part.~
	ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/lm96163/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/connector/connp4/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/mt40a1g16_96fbga/part_table/~
	part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/thvd1550/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/electro_mechanic/labtestpoint/part_ta~
	ble/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/connector/connj5_4pth/part_table/part~
	.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/trsf3232e/part_table/part.pt~
	f.
      INFO(SPCODD-181): Loading ./archive_libs/diode_led/diode_bidir/part_table/part~
	.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/ut_standard/id/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/ut_standard/mh/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/ltm4620_pre/part_table/part.~
	ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/ltm4620_pre/part_table/part_~
	20121220.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/tps53515/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/tps51200/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/mic68200_pre/part_table/part~
	.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/lt8640s_lt8643s_lt8642s/part~
	_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/dp83867/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/sznup2105/part_table/part.pt~
	f.
      INFO(SPCODD-181): Loading ./archive_libs/inductor/chock4_cm_a/part_table/part.~
	ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/sznup1105/part_table/part.pt~
	f.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/lptm21l_bg100/part_table/par~
	t.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/tps7a6601/part_table/part.pt~
	f.
      INFO(SPCODD-181): Loading ./archive_libs/connector/connj6/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/rj45_wml_con/part_table/part~
	.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/electro_mechanic/hdr_1x3/part_table/p~
	art.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/sn74avc4t774/part_table/part~
	.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/tpd2eusb30/part_table/part.p~
	tf.
      INFO(SPCODD-181): Loading ./archive_libs/ic_digital/ic_74lvc1g126/part_table/p~
	art.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/93aa56b/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/ft2232hq/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/discrete_pre/crystal4_2b_pre/part_tab~
	le/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/electro_mechanic/con_b2b_699/part_tab~
	le/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/discrete/q_pnp/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/discrete/q_fet_n_enh/part_table/part.~
	ptf.
      INFO(SPCODD-181): Loading ./archive_libs/digital/u_cpu_efm8sb1/part_table/part~
	.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/logic/u_and_2in/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/memory/u_mem_ee_i2c/part_table/part.p~
	tf.
      INFO(SPCODD-181): Loading ./archive_libs/logic/u_buf_od/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/logic/u_buf_3_state/part_table/part.p~
	tf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/adg3304bruz/part_table/part.~
	ptf.
      INFO(SPCODD-181): Loading ./archive_libs/mechanic/mec_standoff/part_table/part~
	.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/electro_mechanic/con_m2_pci_exp/part_~
	table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/logic/u_levshft_3state/part_table/par~
	t.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/memory/u_mem_fl_ser_512kx8/part_table~
	/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/digital/u_pcie2sata_88se9170/part_tab~
	le/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/power_supply/u_power_sw/part_table/pa~
	rt.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/power_supply/u_vreg_ncv59748/part_tab~
	le/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/discrete/r/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/discrete/d_3pin_cc/part_table/part.pt~
	f.
      INFO(SPCODD-181): Loading ./archive_libs/discrete/c/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/discrete/q_npn/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/discrete/d_esd/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/analog/u_sw_load/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/discrete/d_esd_diffpair/part_table/pa~
	rt.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/electro_mechanic/con_sd_socket/part_t~
	able/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/electro_mechanic/sw_spst_pb/part_tabl~
	e/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/discrete/q_fet_p_enh/part_table/part.~
	ptf.
      INFO(SPCODD-181): Loading ./archive_libs/power_supply/u_swreg_tps53015/part_ta~
	ble/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/tps7a5401/part_table/part.pt~
	f.
      INFO(SPCODD-181): Loading ./archive_libs/connector/connj2/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/ic_power/tps54320/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/clocks/xtal_4pin/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/electro_mechanic/con_hdmi/part_table/~
	part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/tpsm84624molr/part_table/par~
	t.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/max9296/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/lm21215amhx#2d1/part_table/p~
	art.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/srp6540/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/sn65hvd235qdrq1/part_table/p~
	art.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/clocks/sit9120/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/fuse2/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/mtfc8gakajcn_153fbga/part_ta~
	ble/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/ksz9896c/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/osc_cryst/crystal2/part_table/part.pt~
	f.
      INFO(SPCODD-181): Loading ./archive_libs/electro_mechanic/hdr_2x4/part_table/p~
	art.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/connp20_sfp_212/part_table/p~
	art.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/digital/u_rst_tps3808/part_table/part~
	.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/discrete/d/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/micro_usb_con/part_table/par~
	t.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/discrete/tr_enet_magcom/part_table/pa~
	rt.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/sp3003/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/tlin1022/part_table/part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/power_supply/u_ldo/part_table/part.pt~
	f.
      INFO(SPCODD-181): Loading ./archive_libs/digital/u_enet_88e1512p/part_table/pa~
	rt.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/electro_mechanic/con_sata/part_table/~
	part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/electro_mechanic/con_usb3/part_table/~
	part.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/sata_connector/part_table/pa~
	rt.ptf.
      INFO(SPCODD-181): Loading ./archive_libs/flyslice/xczu7ev_ffvc1156/part_table/~
	part.ptf.
 *  Loading State Files  *
Loading ./worklib/adas_mpsoc_fx806dv/packaged/pxl.state.
 *  End loading State Files  (00:00:00)  *
 *  Starting to assign physical parts.  *
 *  End assigning physical parts.  (00:00:02)  *
 *  Packaging  *
#1   ERROR(SPCOPK-1138): A hard location was found on instances of different p~
	hysical part types. Refer to error (1149) for a complete list of instances ass~
	igned this location.
        Schematic instance: @ADAS_MPSOC_FX806DV_LIB.ADAS_MPSOC_FX806DV(SCH_1):~
	PAGE16_I330@FLYSLICE.MTFC8GAKAJCN_153FBGA(CHIPS)
        Physical Path: @adas_mpsoc_fx806dv_lib.adas_mpsoc_fx806dv(sch_1):page1~
	7_i330@flyslice.mtfc8gakajcn_153fbga(chips)
        Instance physical part: MTFC8GAKAJCN_153FBGA_BGA153-MICRON,MTFC64GAKAE~
	EY-4MIT,MTFC64GA
        Package: U48
        Package physical part: MTFC8GAKAJCN_153FBGA_BGA153-MICRON,MTFC64GAKAEE~
	Y-4MIT,MTFC64GAKAEEY-4MIT
        The same value for location on instances of different physical part na~
	mes is not supported. Correct the location for the appropriate instance(s) in ~
	Design Entry HDL.
	Details: This error occurs due to the assignment of the LOCATION value to two different~
	 types of instances, such as LS00 or LS241. This error often occurs (as is the~
	 present case) with ERROR 1149. Refer to ERROR 1149 for a complete list of ins~
	tances assigned to this location. To address the error, change the LOCATION va~
	lue of one of the instances.
			Other likely cause: This error may also occur if a new (unpackaged) symbol ~
	does not have a placeholder for the PATH property. When you save a design with~
	 such a symbol, the PATH property of the symbol is replaced by the original va~
	lue of the PATH property as no placeholder can be found. In addition, during b~
	ackannotation, the canonical path of the part is not found and as a result, th~
	e value of the LOCATION property on the board is not honored. This leads to a ~
	duplicate LOCATION property on parts and results in this error. Add the PATH p~
	laceholder on new symbols to avoid this problem.
#2   ERROR(SPCOPK-1149): Found a hard location 'U48' for
	PAGE16_I329@FLYSLICE.MTFC8GAKAJCN_153FBGA(CHIPS) (MODULE: ADAS_MPSOC_FX806DV; ~
	PART: MTFC8GAKAJCN_153FBGA)
	7_i329@flyslice.mtfc8gakajcn_153fbga(chips)
        A hard location on instances of different physical part names is not s~
	upported. Correct the location for the appropriate instance(s).
	Details: This error message occurs along with ERROR 1138. The message shows the LOCATIO~
	N value, which is the same for two different physical parts. For instance, the~
	 LOCATION value of U1 is defined for both, LS00, and LS241. Packager-XL does n~
	ot support the same hard location on instances of different physical part name~
	s. Therefore, correct the location for the appropriate instance(s). For exampl~
	e, change the LOCATION value of U1 for either LS00 or LS241.
#3   ERROR(SPCOPK-1149): Found a hard location 'U48' for
	PAGE16_I330@FLYSLICE.MTFC8GAKAJCN_153FBGA(CHIPS) (MODULE: ADAS_MPSOC_FX806DV; ~
#4   ERROR(SPCOPK-1149): Found a hard location 'U48' for
	PAGE16_I331@FLYSLICE.MTFC8GAKAJCN_153FBGA(CHIPS) (MODULE: ADAS_MPSOC_FX806DV; ~
	7_i331@flyslice.mtfc8gakajcn_153fbga(chips)
#5   ERROR(SPCOPK-1149): Found a hard location 'U48' for
	PAGE16_I332@FLYSLICE.MTFC8GAKAJCN_153FBGA(CHIPS) (MODULE: ADAS_MPSOC_FX806DV; ~
	7_i332@flyslice.mtfc8gakajcn_153fbga(chips)
INFO(SPCOPK-1441): 5 errors detected
INFO(SPCOPK-1444): No warnings detected
INFO(SPCOPK-1448): Use Tools - Markers - Packager in Design Entry HDL to highl~
	ight the instances for which errors or warnings are reported
    Start time   13:22:33
    End time     13:22:47
    Elapsed time  0:00:14
 *  FATAL ERROR PackagerXL exiting with status 2  *
  • DavidJHutchins
    DavidJHutchins over 6 years ago +1
    The log file shows the issue being refdes U48 on 2 different pages ( 16 & 17 )
  • DavidJHutchins
    0 DavidJHutchins over 6 years ago
  • TomChen1228
    0 TomChen1228 over 6 years ago in reply to DavidJHutchins
    Thank you very much. I will check it.  ^___^
