  2. Design Entry HDL
  3. Bottom Up Hierarchical Design
  • Subscribers 26
  • Views 16234
mmov
mmov over 6 years ago
I was reading through Cadence tutorial on how to create a bottom up design i.e. starting with low level board schematic then creating a higher level schematic, however I'm not able to do this properly. What ends up happening is that I  create a single hierarchy branch, with all my schematic pages below it.
I have my complete schematic where I have everything my board will be using microprocessor (MP), DRAM, Flash etc. and I want to create 2 blocks: 'CPU' (containing the MP circuitry) and 'MEMORY' (with DRAM and Flash circuitry).
How can I create these individual symbols and include them all as blocks on the higher level diagram, after I completed my schematic?
  • steve
    0 steve over 6 years ago
    Watch this https://www.youtube.com/watch?v=xZwYYfvSz1A&t=3s
  • mmov
    0 mmov over 6 years ago in reply to steve
    This is for OrCAD Capture, I'm using Allegro Schematic Entry
  • steve
    0 steve over 6 years ago in reply to mmov
    OK see of this helps https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000009ESfAUAW&pageName=ArticleContent
  • tmd63
    0 tmd63 over 5 years ago
    I have a similar issue. I have a design with a single root and 20 pages. I want to separate each page so that a root page holds the sub-blocks for each page to run like a hierarchy.
    I know how to add ports to the lower page schematics. But how do I split the lower pages into separate blocks for inclusion in the root page?
