  2. Design Entry HDL
  3. Concept HDL SKILL Solution.
  • Subscribers 25
  • Views 7399
ABIKRISHNA
ABIKRISHNA over 3 years ago
How to change the component property in library by skill code.
i am having the script to change the component property in library but it gives popup message for every property changing.
Is there any right way to change the property in library without popup messages.
  • JuanCR
    JuanCR over 3 years ago
    Hi Abikrishna,
    Can you share the snippet of code (or the script) you're using? I'd like ot test it at my end.
    • Vote Up -1 Vote Down
  • ABIKRISHNA
    ABIKRISHNA over 2 years ago in reply to JuanCR
    I apologies for the delay reply JuanCR.
    Actually I suppressed the warning message during changing the property with the code.After that i released the suppress as in the design entry HDL.
