  2. Design Entry HDL
  3. How to assign signal name to specific PATH automaticall...
  • State Suggested Answer
  • Answers 1
  • Subscribers 24
  • Views 5829
How to assign signal name to specific PATH automatically
ronniezh
ronniezh over 2 years ago
Hi All,
I need to assign many signal names to corresponding PATH and LOCATION. The mapping relationship between signal name and PATH are specified in a table.
As shown in below picture, the PR? is an identical component which is in multi-symbol version format. I can use copy/paste, multi-section to generate below circuits.
This is what I want to do. Assign different signal name to each of these independent components.
But the PATH(pin number in daughter card) and net name connections are specified in a table.  Since the count of block abovementioned I need to create and assign is too many, it will be easy to have error if I have to do it manually and take too long time.
I tried to create group and open the PATH/signal name in text change editor, but it doesn't work even I add signal name in it.
Does anyone know if there is any way to do this automatically?
  • rg13
    rg13 over 2 years ago +1 suggested
    There does not seem to be any automated way to achieve this.
  • rg13
    0 rg13 over 2 years ago
