  2. Design Entry HDL
  3. Add Prefix into the current schematic
  • Subscribers 24
  • Views 6467
Son
Son over 2 years ago
I know to add a prefix to the schematic but I don't know how to add a prefix to the current schematic and keep the same ref. des.
For example, my current schematic ref des like; U1, C1, and R1.
I want to add a prefix "09" into the ref des after "U". New schematic ref des are U091, C091, and R091.
Can you please help?
Son Nguyen
  • rg13
    rg13 over 2 years ago +1
    You can achieve it by defining the REFDES_PATTERN for your design. In this case you can define refdes_pattern as follows: “($PHYS_DES_PREFIX)(09)[0-9](1)” For more details on this, you can refer…
  • Son
    Son over 2 years ago in reply to rg13 +1
    Thanks rg13 for your responding. My current schematic has the Ref Des "J605". How can I add "09" into this Ref Des after "J" and before "605" J605 => J09605 I can do manually but I'd add "09" for…
  • srish09
    srish09 over 2 years ago in reply to Son +1
    You can try updating the reference designators through de-hdl console commands and change editor. Check this article: Article (20493540) Title: How to update multiple part references in Concept HDL design…
  • rg13
    0 rg13 over 2 years ago
    For more details on this, you can refer Application Note "Practical Applications of REF_DES_PATTERN" by following link from Cadence online support portal:
    Article (20416521) Title: Practical Applications of REF DES PATTERN
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od000000050Q0EAI
    Let me know how it goes.
  • Son
    0 Son over 2 years ago in reply to rg13
    J605 => J09605
    I can do manually but I'd add "09" for entire schematic.
    Son
  • srish09
    0 srish09 over 2 years ago in reply to Son
    Article (20493540) Title: How to update multiple part references in Concept HDL design at once
    URL: support.cadence.com/.../ArticleAttachmentPortal
