  2. Design Entry HDL
  3. Change the name of a group of similar nets
  • Subscribers 25
  • Views 6815
AGard
AGard over 2 years ago
At a high level, I want to change all nets within a multi-page schematic with a certain substring to another while maintaining the rest of the string. Example: 2 signals on 2 pages are: "this_signal_name_1" "this_is_another_signal." I want to change "this" to "diff_string" and have the 2 signals on different pages updated to "diff_string_signal_name" and "diff_string_is_another_signal." All prefixes and suffixes of the substring should be maintained.
To clarify the question, I have a multi-page schematic in Allegro Design Entry HDL. There is a signal name applied across the pages that I wish to change with one set of commands, e.g. using a Global Property Change. Here is the problem. The nets all have the same prefix, but have different naming conventions given their location and connection within the schematic. Example "I2C_TX_Temp_Sense," I2C_TX_DIMM_1," "I2C_RX_MUX_3" all need to have "I2C" changed to "I3C." Do not adhere to this example rigidly, this is just the general concept. The problem I have with the Global Property Change is that I can find all nets with the "I2C" prefix when I use "I2C*." When I try to change it to "I3C*" in the Value category, it will change all nets across the design to "I3C*" instead of saving the suffix. I know there are ways to go page by page and change the net names as a group using the "find SIG_NAME=I2C*" command then changing the test file with CTRL+E, but this seems inefficient.
I have so far been unable to get the "find globalFind {[Entire Design]}..." or "find -scope "Entire Design" ..." commands to work. I cannot find proper documentation in the Cadence Help portal for what I am looking for. I would think this is the correct idea given that I can accomplish this task on individual pages with the "find SIG_NAME=I2C*" command.
AGard
  • srish09
    0 srish09 over 2 years ago
    Refer this article. This might help.
    Title: How do I change a portion of signal names in a design with a search and replace type of mechanism?
    URL: support.cadence.com/.../ArticleAttachmentPortal
  • jc teyssier
    0 jc teyssier over 2 years ago
    In my memory (not using concept hdl since a while), it is possible with ctrl+e
    select all the wanted nets, (in console; create group in select command) then type ctrl+e : it will open a text editor (you have to setup your preferred one before, say notepad++ or vim) with th signames. Here you can edit/substitube whatever you want .
    While saving, the texts will be udpated in schematic pages.
    I do not remember if i already do this on multiple page but i guess it will work.
    Warning: the second solution is very risky:
    An other way but more risky (have already work for me in the past but i do not recommend it since the use of constraint manager by concept, should work but the toll will ask you to concert from 'pre 16.x revision' "normally" not a problem but at your own risk):
    what i done in pre 16.x of concept:
    concept schematic is composed of files.
    page 1 is:
    page1.cpc
    page1 .csa
    page1 .csb
    page1.csv
    You can delete *.cpc *.csb and *.csv files.
    . csa is ASCII file and can be edited in text editor
    Edit what you want in these file. While opening , say page1 in concept and write the page, it will recreate  the deleted files.
    Do this for all pages
    The schematic is up to date.
    you may have also to delete +.dcf and *.xcon file : i guess you will loose constraints entered in concept. :
