  2. Design Entry HDL
  3. How to import the Design Entry DHL schematic Design to OrCAD...
  • State Suggested Answer
  • Answers 2
  • Subscribers 25
  • Views 13255
How to import the Design Entry DHL schematic Design to OrCAD Capture Schematic
RohitRohan
RohitRohan over 1 year ago
Dear Community,
I have a schematic design created in Design Entry HDL, and the file is saved with the .cpm extension. I am currently looking to import this schematic design into OrCAD Capture.
If anyone has a document or video tutorial outlining the detailed steps or procedures for importing a Design Entry HDL schematic design (.cpm) into OrCAD Capture, I would greatly appreciate it if you could share it with me.
Thank you in advance for your assistance and support.
Best regards,
Rohit Rohan
  • Gowtham P
    Gowtham P over 1 year ago +1 suggested
    Hi Rohit, As of now, there is no direct way to convert Design Entry HDL schematic to Orcad CIS schematic. The reason is that concept symbols have a lib cell view structure. Hence for every symbol…
  • Gowtham P
    0 Gowtham P over 1 year ago
    Hi Rohit,
    Hence for every symbol tool will require this view.
    #1. The longer route is to convert the DEHDL libraries to Capture Libraries by exporting concept library/cells into Capture's format which is .olb and redraw the circuit.
    {  How to?
    Go to: Project Manager > Tools > Library tools > Export > Design Entry HDL to Orcad Capture. This will convert your concept library/cell into .olb format. }
    #2. The shorted way is through the Elgris/Third party Translators, however this conversion is not very reliable.
  • RohitRohan
    0 RohitRohan over 1 year ago in reply to Gowtham P
    Hi Gowtham,
    Thank you for your reply. I have a few doubts:
    1. Is the Elgris Translator a paid tool?
    2. If we have the .cpm file, does it directly convert into a .dsn file?
    3. Regarding the first method, after converting the .cpm file to an .olb file, how can I proceed to convert it into a .dsn file?
    Your guidance on these points would be greatly appreciated.
    Best regards,
    Rohit Rohan
  • Gowtham P
    0 Gowtham P over 1 year ago in reply to RohitRohan
    Hi Rohit,
    For points #1 and #2, I believe the answer is YES. However, you may need to reach out to Elgris Team directly for further clarification.
    Regarding point #3, the process involves converting the DEHDL library symbols (not the .cpm file) into .olb symbols that are compatible with Capture CIS. Once the conversion is complete, you'll need to use those symbols to re-draw the schematic in Capture CIS.
  • RohitRohan
    Hai Gowtham,
    Thanks for the response Grinning
  • luvishis
    0 luvishis over 1 year ago in reply to RohitRohan
    Elgris Technologies, Inc  (www.elgris.com) provides services and tools to translate HDL to OrCAD.
    The conversion comes with 100% netlist guarantee.
