  2. Design Entry HDL
  3. Issue with Signal naming in design entry HDL
  • Subscribers 24
  • Views 4130
SIVAREDDY TI
SIVAREDDY TI over 1 year ago
I am working on a hierarchical design ,in the subblock i am trying to name the signals names of the Devicefrom place signal name -->entering all the names
but it should be coming serially in the actual schematic page but they are not appearing to name the nets.
  • Gowtham P
    0 Gowtham P over 1 year ago
    Hi SIVAREDDY TI ,
    I need some more data to help you with this requirement. I will be contacting you through another channel for this.
  • SIVAREDDY TI
    0 SIVAREDDY TI over 1 year ago in reply to Gowtham P
    Hi Gowtham, no response after this. but the issue got solved after restarting the PC and allegro. but  i would like to know if there are any settings in the Tools-->options which can enable or disable this .
    Also cadence library is not very stable now a days, few days back i have added a part and requested for a replacement part in the library, the library team told its been added and i don't see the part yet in library. surprisingly the old part which is there already in the schematic also not visible in the library.
    you can reach out to me on 9000328620/v.sivareddy@ti.com
