  2. Design Entry HDL
  3. Assign Xnet pins in HDL design
  • Subscribers 24
  • Views 4895
EO202501307419
EO202501307419 over 1 year ago
 I have a problem defining my Xnets. I already defined my Xnets in PCB alegro, layout . Since layout only creates Xnets for the pins that has Xnet property, I need to define Xnet pins in my HDL entry design, schematic as well. However, There is no ^ edit part^ in HDL entry when I right click on it,  so I can add class, or define pins. Where can i set this?
  • rg13
    0 rg13 over 1 year ago
    You can apply RMB, Open > sym_1 or sym_2....
    OR if you need to edit part, you can open the cell in Part Developer and then can make the changes.
  • EO202501307419
    0 EO202501307419 over 1 year ago in reply to rg13
    https://files.fm/u/vsza2x5s3r
    Still not able to find it.
  • EO202501307419
    Still not able to find it:
  • EO202501307419
