  2. inspectAR
  3. Create a markup using inbuilt screenshot markup tool
  • Subscribers 10
  • Views 1313
TechiEE12
TechiEE12 over 3 years ago
Engineers spend several hours preparing lab documentation, user guides, and so on and struggle to get a suitable markup drawing to illustrate specific steps.
With the inspectAR screenshot markup tool, you can achieve this quite easily. This feature takes a screenshot of the current view in inspectAR, and then you can mark the photo saved, much like a paint program. It allows adding your custom drawings, directions, and instructions to the image. Once you complete the markup, the tool has a save option that will enable you to store the photo in the local drive or add it to the project that you can share with anyone.
This feature can be beneficial for passing on the information when a PCB needs to be modified, like replacing a part, shorting two pins, and so on. The feature helps remove any dependency on third-party tools for markup and offers a one-stop solution.
